Exhaust system installation
Old Feb 22, 2005 | 08:58 PM
Will99FRC's Avatar
Will99FRC
C7 of Year Finalist (stock) 2019
Default Exhaust system installation
My neighbor has just bought a C6. He wants to get a new exhaust system put on but is unsure who should do the work. Does the dealer have to install the exhaust system to keep the waranty valid? Will the dealer even install a non GM exhaust system? Wiil the new system effect his California emmisions if he just modifies from the catalyst back? Or should he just go to a good muffler shop? Any help would be greatlt appreciated.
Old Feb 22, 2005 | 09:02 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Catback exhaust is legal in all 50 states, and no, the warranty won't be affected. A dealer does not have to do it. Very simple job on a C5, not sure about the C6 exactly...but safe to say any fairly mechanicly inclined person should have little trouble with it.
Old Feb 22, 2005 | 09:15 PM
Will99FRC's Avatar
Will99FRC
Thanks for the help.
Will dealers install non GM exhaust systems?
Old Feb 22, 2005 | 09:23 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Depends on the dealer. Some will, some won't.
Other than the warranty claim aspect, dealer's service shops are pretty much their own seperate business...If you're footin' the bill for the install labor, like most any mechanic's garage they'll do most anything you ask of them (within reason). You'll just pay more for it.
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
DON'T do this through the dealer. Even if they would install it they'd charge way too much. If you're not doing an X-Pipe it's about as simple as "wax on/wax off". I installed an X and GHL's a year and a half ago. Took 3 hours with a lift I rented for $10/hr including tools.
If that's not available, any good muffler/brake shop should be able to do it reasonably priced. But I'd be there the whole time under the car with them because I doubt they've done it on a C6 yet.
Good Luck
PS: it won't affect warranty or emission.
Old Feb 22, 2005 | 09:26 PM
Will99FRC's Avatar
Will99FRC
Thanks for your help guys
Old Feb 22, 2005 | 09:42 PM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
I helped a friend install some B&B exhaust on a C6. We used a lift, even then we had to SawZaw the old passengers side off. Not enough room between the gastank and tranny to get it out. To install the pasenger side, we had to drop the H pipe and we had to unbolt the passenger gastank shielding. After the insall we bolted the shielding and H pipe back in place. Drivers side went smoother, but still tight.
It was MUCH more difficult than a C5 exhaust install! Have a pro do it, save yourself the trouble.
AZC5
Old Feb 22, 2005 | 10:52 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
To Exhaust system installation
