Actually it is a pretty easy job. I just changed all 4 of mine to slotted and drilled and it took about 2 hours start to finish. The worst part was getting the car in the air.
The calipers bolt to a black bracket that reaches from behind the hub to the front. This bracket holds the caliper. You will find 2 bolts, 21MM I think, that secure each bracket. Remove those, no easy task, they are very tight, my impact wrench helped but it was tough to get in position. A 18 inch breaker bar did the trick.
Once loose, make sure you don't let the calipers and bracket hang from the brake line.
The rotors took a few taps from a hammer and off they went!
Repeat 3 more times and that is all it took. If your pads fall out just make sure you fit them in place the same way they came out.
The bolts he is talkiing about are metric, and I think 21MM. The book says 125 Ft lbs for the proper torque also use red locktite on the threads. You will also find little star like washers on one of the wheel studs if original rotors. These were put on to hold the rotors in place at the factory. You do not have to re-use them.
