So I hear the UPS truck outside and run to meet it with a my socket set in hand (which really confuses the driver), and sure, 'nuff, my custom Crow 5 point harness belts from WCC have arrived!!!
YAY
So, with just a few turns of the wrench on the bolts on the harness bar and floor mounts and I'm all set to try out my new system. I plop down into the seat, buckle up the seat, shoulder and submarine strap and shut the door.
WARNING!!!!
If you are trying out a new harness belt set and your car has MEMORY SEATING - you should always let the harnesses ALL THE WAY OUT before strapping in and setting off the memory feature. Else you will get scrunched up in a way, and in places I'm sure Grumpy won't let me describe here. Particularly by the submarine strap!! OUCH!!!!
thats great! Youve got the best write ups Jim....are you tc and gears done yet?
Chris
It might be a couple more consutling jobs for the gears. Still debating the TC as I'm not dragging the car. I'm just between gears on a lot of courses and want a little more low-end torque in that range.
