Resetting the Computer
Old Feb 24, 2005 | 08:20 PM
01pewtervette's Avatar
01pewtervette
Default Resetting the Computer
I use to have a 2001 LS1 Trans Am and was told that disconnecting the Battery for 20 minutes would wipe out the driving habits the computer had learned and stored. I test drove a 2001 Vette 3 weeks ago locally and it ran like a Mother! I just bought a fully loaded, super clean and low mileage 2001 this weekend and dont think it is as quick. It was owned by a woman who took it out of here garage on the weekends and babyied it. Could the computer have stored this and needs to be wiped to get it back to a original stock baseline? Thanks for any help. The vette has an auto, 3.15 gears and adjustable ride control.
Tony
Old Feb 24, 2005 | 08:35 PM
C5Jim's Avatar
C5Jim
Huh??????????
It's a computer, not a electronic diary.
The computer bases engine performance on engine parameters and climate conditions.
I wish it would adjust for driver conditions. Maybe it would get some of these slow-pokes to speed up or better yet move over.
Hey, you might have come onto to something here!!!!
Old Feb 24, 2005 | 09:11 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Originally Posted by C5Jim
Huh??????????
Amazing, someone asks a question and basically gets laughed at.
Well, maybe it is my turn to laugh. Ever hear of adaptive strategy; guess not. Modern auto computers use more than inputs from various devices to control the engine/trans via outputs to various other components. They also use algorithms that detect the driving habits of the driver, and adapts certain functions in the PCM/TCM to how the vehicle is driven.
Generally, adaptive strategy is used on the transmission side of the PCM, or on a TCM, and is used to adapt the trans shifting for the driver. Used on almost all trans controllers that control a 5-speed trans, but also used on some 4-speed transmission such as the one used on the Vette.
Aisen Warner makes a 5-speed transaxle used on some GM vehicles that if reprogrammed or the battery is disconnected, the tech has to take it for a twenty minute drive to allow it to adapt. If not, the customer will drive out of the parking lot, and turn around since it will be shifting like a drunk driving a manual. This twenty minute adaptive drive is only to set the main adaptive algorithms, it adapts over a longer period of time to normal driving modes.
In answer to the original posters question, yes, disconnecting the battery should reset the trans adaptives. However, with the 4L60/65E transmissions used, you may not notice that much of a difference. The adaptive algorithms used on the C5 were minimal, and to be honest, since this is an ongoing learning process of the computer, it will adapt to your driving habits in a few hundred miles (or it should).
Old Feb 24, 2005 | 09:41 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
I believe the above poster stated "it will re-learn your driving habits/style"! I believe that to be true
Old Feb 24, 2005 | 09:44 PM
01pewtervette
Thanks for the very indepth response to my question. I knew I had read all about it on LS1.com a while ago but couldn't really remember the facts. Thanks again WhiteC5Vette
Old Mar 1, 2005 | 06:24 PM
01pewtervette
I found the problem - The rear has 2.73's and I am assuming the other had the optional 3.15 on the auto. Anyone changed to 3.73's yet?
Old Mar 1, 2005 | 06:42 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
PLenty ... I'm looking at 3.90
Old Mar 1, 2005 | 07:14 PM
Xlr8tnC5's Avatar
Xlr8tnC5
That is an F-body trick that worked on my 2002 Formula. Computer would dump fuel maps after pulling battery power. I am not sure about the C5. A GM is a GM right? So it should work on a C5. I think I just figured out Scratch's secret.
Old Mar 1, 2005 | 08:01 PM
WWK888's Avatar
WWK888
You might consider getting a shift kit and higher stall converter (along with 3:73's). It would turn your car in to a beast!
To Resetting the Computer
