How do i get it lower
Feb 24, 2005 | 11:00 PM
Feb 24, 2005 | 11:01 PM
Feb 24, 2005 | 11:06 PM
Feb 24, 2005 | 11:13 PM
Feb 24, 2005 | 11:20 PM
Feb 24, 2005 | 11:25 PM
Senior Member
Cruise-In V Veteran
Remove the front adjusting bolt. Longer bolts in the back, or
coilover shocks.
Feb 24, 2005 | 11:27 PM
Ive got longer rear bolts ordered.
If i take out the front bolts will i have any problems?
Feb 24, 2005 | 11:33 PM
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Quote:
Originally Posted by DEALER1
19-20 wheels
My 19/20" tires are the same overall height as the stock 17/18's. How does that make it lower?
(my car has been lowered considerably...but the wheels/tires did not affect the height)
Feb 24, 2005 | 11:35 PM
Senior Member
Cruise-In V Veteran
Just watching out for roadkill!
Put a piece of rubber between the spring & A-arm. No Problem!!
Feb 24, 2005 | 11:36 PM
You can get longer bolts or cut the bushings!
Feb 24, 2005 | 11:38 PM
Another inch??? I don't even have mine lowered all the way on stock uncut bolts, and I can't even stick the toe of my boot under the rubber side dams! Geez, if I went any lower, I could earn a couple extra bucks from the city as a street sweeper...
Feb 24, 2005 | 11:41 PM
I want the tires tucked
Feb 24, 2005 | 11:45 PM
Senior Member
Cruise-In V Veteran
Then....It's coilovers.
Feb 24, 2005 | 11:51 PM
Thats what im talkin about
Feb 25, 2005 | 12:00 AM
Quote:
how would you get into...out of driveways....over speedbumps with a car that low
LOOKS AMAZING THOU!!!....is it just a garage queen???
