Will the backs, fit the fronts....??
I want to go with the C6 wheel in size 19x10 and whatever the biggest tire without tubbing will fit on the rear. (also have this posted in wheels and tires, but no answer yet).
Thanks for any input....
Your stock rear tires will be taller than a 295/35 or a 315/30 so don't count on AH being happy with this setup.
Get a lower profile tire such as 265/35/18 or 275/35/18.
The tires should not be a problem since I have gone to 285/35/18 up front when I used to have CCW 18x10.5 up front.
I was just worry the rear's offset and the front's offset are different.
Thanks,
-Mike
Thanks,
-Mike
Compare to a stock Z06 9.5" front wheel, which is 54mm offset and sticks out a lot more, it's not tucked in the fender at all like C5 wheels are, it fits flush with the fender.
In short, from an appearance standpoint, the rear 9.5's on the front stick out only 1/4" more than the stock 8.5 front, which is still about 3/8" less than the stock Z06 9.5's stick out.
So, appearancewise, they're fine.
What about inner clearance?
The stock 8.5 has 7" backspace.
The stock Z06 9.5 front has 7 3/8" backspace
The 9.5 rear has 7 3/4" backspace.
Whether that presents a problem, I don't know for sure. But I've not heard of any clearance problems from people who have done this swap before,so I'd guess theyr'e ok. It likely would only be a potential rub issue at a full turn if anything.
Sorry if this was confusing....but there are the numbers, and how they affect fitment.
From what you all said, I'll buy my C6 19x10's for the rear, and wait till my current tires wear out, then do the front to rear swap and add new rubber....Thanks again..!!
In this case the answer is no because a 295/35 or a 315/30 would be shorter than a 275/40 This is assuming you have AH.
Just be sure to get a 275/35 for a 295/35 or a 265/35 for a 315/30
The wheels would work, but I wouldn't use the tires. Too tall. Use a 265/35/18 or 275/35/18.
