oil pressure
Old Feb 27, 2005 | 05:39 PM
bpc4me's Avatar
bpc4me
Default oil pressure
Hey all,
My oil pressure is pegged at 130.
Where should it be and if the 130 is not correct, what to do?
Old Feb 27, 2005 | 06:40 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
It sounds like your oil pressure sensor is bad.
Old Feb 27, 2005 | 06:46 PM
AdamC5's Avatar
AdamC5
Not sure what the problem could be (I agree, could be the sensor) but 130 is definitely not correct
Old Feb 27, 2005 | 07:34 PM
EscapePod's Avatar
EscapePod
Usually between 38 and 60 psig
Old Feb 27, 2005 | 07:35 PM
RCK1999's Avatar
RCK1999
99.9% chance of bad sensor! Common problem. To be sure, turn ignition key on but don't start engine. If you get a pressure reading with the engine off, you've got a bad one. Tech Tip has the details for replacement.
Old Feb 27, 2005 | 07:48 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
With the above. The sensors shot. I think there's a DIY'er post in the Tech section on how to replace it.
Old Feb 27, 2005 | 08:12 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I had my TR224 installed last month, and with that I had the LS6 ported TSP oil pump put in. I think I gained 5-10 PSI during normal use. Today after the oil temp was around 130 degrees, I jumped on the car in 2nd , 3rd and into forth until I notice my oil pressure jump up to high 70's. I quickly shifted into 5th and 6th, and the pressure dropped back into the "nromal " range of 45 PSI. Its never been that high becuase. Could it be that the oil was still a little cold. It was in the mid 30's here in NY today. I have 38 % oil life left.
what do you think ?
Old Feb 27, 2005 | 11:38 PM
ls1vette97's Avatar
ls1vette97
Mine was reading about 70 psi when i got on it one night, sort of scared me for a min then it dropped. Next day when i started it, the gauge was reading 129 psi .... still havent got around to fix it yet, but thats next on my list of things to do.
Old Feb 28, 2005 | 04:41 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I am gonna go with bad sensor. BTW..where ya been man??
Old Feb 28, 2005 | 06:43 AM
Originally Posted by FLACHUSNRET
35-45
That's where I would be looking for the source of the problem.
Old Feb 28, 2005 | 06:00 PM
bpc4me's Avatar
bpc4me
hey man... well got engaged for one... Also got a new dog so both have been keeping me busy. Looking forward to going to another event soon.
Old Feb 28, 2005 | 08:03 PM
leaftye's Avatar
leaftye
what do you think ?
The pump you bought is shimmed as well. The shim doesn't affect the normal oil pressure, all it does is bump up the blowoff pressure. Now when you get into the pressure that GM was too much, insteading of the pressure getting bled off, you go even higher.
To oil pressure
