Oil change
Old Feb 27, 2005 | 07:27 PM
FastAssVette's Avatar
FastAssVette
Default Oil change
This is the first time i am going to change my oil by lifting the car with a floor jack. I bought a low profile jack to get under the car.But i have seen the pads for liffting the car in mid america. I was woundering if it is really nessesary to do that. Thanks, Bud
Old Feb 27, 2005 | 07:41 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
I would recommend them...you could probably find something else to use instead.
Old Feb 27, 2005 | 07:47 PM
Corvette Tommy's Avatar
Corvette Tommy
St. Jude Donor '08-'09
Hockey pucks work fine
Old Feb 27, 2005 | 07:55 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Rhino ramps for front .........lift the rear from the center back
Old Feb 27, 2005 | 07:58 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
I hope you are also going to use jackstands. No, jacking pucks are not necessary if you place two jackstands under both the front and rear crossmembers. Here is a little tutorial for lifting without the pucks.
http://www.z06vette.com/diy_lift.php
good luck and please be safe under there.
Old Feb 27, 2005 | 07:59 PM
6 speed Sid's Avatar
6 speed Sid
Use a block of wood, 2 x4 etc, and jack by using the front cross member. Span the ribs with the wood block to spread the load and you will be fine.
Old Feb 27, 2005 | 08:00 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I like doing it without the pucks as stated above. So much easier. And stable.
Old Feb 27, 2005 | 08:20 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
This is how I do it!
Old Feb 27, 2005 | 11:32 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Yep, and if you have a sloped driveway...
http://forums.corvetteforum.com/show...post1549761662
Old Feb 28, 2005 | 12:10 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I 3rd The Motion. Doing mine tomorrow too.
Old Feb 28, 2005 | 12:18 AM
LS1_redvette's Avatar
LS1_redvette
I don't know if I would trust the Z's method with the 2x4's. It seems as tho that would be so unstable and not worth the chance of having a 3000+lbs car either slipping and cracking the support or even worse falling lower.
LS1_redvette
I don't know if I would trust the Z's method with the 2x4's. It seems as tho that would be so unstable and not worth the chance of having a 3000+lbs car either slipping and cracking the support, or even worse falling lower.
Old Feb 28, 2005 | 12:30 AM
ALLEGRO's Avatar
ALLEGRO
This is a very safe and effective way to do it!
To Oil change
