Blackwing Filter Cleaning Advise...
Old Feb 28, 2005 | 06:08 PM
PaulaH's Avatar
0PaulaH
Former Vendor
Default Blackwing Filter Cleaning Advise...
I just cleaned my Blackwing filter.. When I went to spray the oil on, it did not spray like we know a spray should. Not a fine spray but rather a stream.. I proceeded to oil it.. Should it have been a fine spray or a steady stream like? What if I got too much on it?
Thanks guys!
Paula
Old Feb 28, 2005 | 06:17 PM
jrose7004's Avatar
jrose7004
I always mix a little alcohol in to help it spray a little better and then the alcohol evaporates and leaves the oil!
Old Feb 28, 2005 | 06:19 PM
PaulaH's Avatar
0PaulaH
Former Vendor
It is in a can....not a bottle with a trigger spray...
Old Mar 1, 2005 | 12:08 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Paula,
My only thought, if you're concerned about too much oil, is to try and absorb the excess with something like cotton batting or a soft cloth - let it rest on the filter or pat very gently, as you want to avoid bending the pleats of the filter. Good luck.
Old Mar 1, 2005 | 12:45 AM
PaulaH's Avatar
0PaulaH
Former Vendor
Thanks, will do that, just to be sure!
Old Mar 1, 2005 | 01:23 AM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
Hmmm, on my '96 vette which had a K&N filter, too much oil would foul up the MAF. Wouldn't the same happen if too much oil was added to the Blackwing on my C5?
Old Mar 1, 2005 | 01:31 AM
wamara's Avatar
wamara
Could very well. Some people here have reported fouling their MAF with excess oil - don't recall/know what brand of filter they had on their cars.
Old Mar 1, 2005 | 01:38 AM
lowdowndirty's Avatar
lowdowndirty
It's oil out of an aerosol can. Hence, the lack of atomization.
Cover as much of the filter as you feel comfortable doing. Let the filter set for at least an hour, then reapply to any bare spots. The entire filter should be dark blue. Let the filter set at least overnight. Wipe down the rubber and any overspray or puddling with a towel. Good luck.
To Blackwing Filter Cleaning Advise...
