Changing Brake Pads
Old Mar 1, 2005 | 05:20 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
Default Changing Brake Pads
I'm going to change to the GM ceramic pads and add the stainless pad covers. Is there a good DIY site or any lessons learned from others doing this? There's all kinds of clips and stuff that came with the new pads.
Thanks....
Old Mar 1, 2005 | 06:31 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
http://forums.corvetteforum.com/show...cement+DIY+job
Old Mar 1, 2005 | 07:33 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Thanks...looks like an Ohio snowy weekend project....
Old Mar 1, 2005 | 07:53 AM
fast2000vette's Avatar
fast2000vette
If you don't already have them, this is a good time to go to a drilled and slotted zinc coated rotor. You can pick them up pretty reasonable for about $250 for a set of 4. It looks really good.
Old Mar 1, 2005 | 07:59 AM
fast2000vette
Oh, to answer your question. They are just like normal cars, except the bolts are torqued to about 120 ft/lbs, a impact wrench will make it much easier but can be done without it. You will have to grind off the little bumps on the back of the pads to install the SS liners. And while you are in there, adjust the parking brake, it has a little star wheel like on drum brakes. Good luck and have fun.
Old Mar 1, 2005 | 11:23 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Thanks...look like I can make quite a project out of thi deal...
Old Mar 1, 2005 | 12:23 PM
BudgetPlan1
I thought the caliper bracket bolts were torqued to 120ft/lbs but the guide-pin bolts (the only ones needing removal to replace pads) were 23 ft/lbs?
To Changing Brake Pads
