Z06 screen install
Old Mar 1, 2005 | 12:29 PM
SilverRoadster00's Avatar
SilverRoadster00
Default Z06 screen install
I just got my screens, found this thread http://forums.corvetteforum.com/show...screen+install
but Patches great pictures don't show. Is there another link I'm not finding?
Old Mar 1, 2005 | 01:43 PM
Patches's Avatar
Patches
Default For anyone else's benefit . . .
If you are replacing a factory installed screen, there are 3 screws holding it on the inside a wire harness attached on the bottom. You can access them by taking off the air dam, the access panel and the screws holding the bottom of the front fascia then reaching in towards the back of the screen bezel from underneath. Here's what the bezel looks like taken out.
I have mine attached to my coupe with Velcro to retain access to the VaraRam tunnels and the fog lights from outside the fascia. Below are a few pics of the velcro strips. I attach the soft, "fuzzy" loop part of the velcro to the screen bezel and the harder hook strips to the front fascia to avoid scratching the paint with the hooks. Use a pice of cardboard over each of the strips of velcro to place the screens and then pull the cardboard out once they are positioned. Use the reverse method to extract them.
Top of fog light recess
Bottom of fog light recess
Top of screen
Bottom of screen
The finished look
Old Mar 1, 2005 | 01:44 PM
SilverRoadster00
Patches PM'd the instructions and pics - THANKS! It's no wonder this is the greatest forum on the net.
Old Mar 1, 2005 | 09:53 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I couldn't have done mine without help from Patches.
Jeff
Old Mar 2, 2005 | 09:01 AM
SilverRoadster00
Looking at the pieces last night and comparing to the pics, it seems to me that the Velcro on the bottom of the screen would be too far back (close tot he fog surround) to match up with the Velcro on the bottom of the recess. Is this just my eyes playing tricks on me?
Old Mar 2, 2005 | 09:37 AM
Patches's Avatar
Patches
Mine match up perfectly. The edge of the bezel reaches the inside edge of the fascia recess. I've been running these for over three years like this with no problems. They are on very securely. It takes some signifcant force to take them off.
Old Mar 2, 2005 | 10:04 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Patches comes through again. Cheers.
Old Mar 2, 2005 | 10:07 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Old Mar 2, 2005 | 10:17 AM
SilverRoadster00
While I'm sure the instructions are spot on, I think my eyes are playing tricks on me. I'm going to have some blind faith and install the velcro just as in the pics. Thanks for all the help.
Old Mar 2, 2005 | 10:25 AM
Patches's Avatar
Patches
It's easy to check. Place your screens in place without velcro and look in through the screen with a flashlight to see where the edge falls. Also, you can measure from where the front of the bezel is to the rear edge of the recess to get an idea of where the velcro will land. I have Velcro on the full length of the bezel, top and bottom, so even if only half of it caught, it would still easily hold the bezel in.
Old Mar 2, 2005 | 10:31 AM
bogiemanjoe's Avatar
bogiemanjoe
Patches, do you have an easier way of putting in the brake duct
screens. Apparently someone walked off with my left side one and I had to buy a new set. Any new Ideas so that they don't walk away again?
Old Mar 2, 2005 | 11:03 AM
MY1STPEWTER's Avatar
MY1STPEWTER
The way I put my brake duct screens in was to grab the middle of the screens with a pair of needle nose pliers and put them in the duct from the front of the car. There is only one way that they will fit. Just take your time and be careful. After you get them in you just pull them into place. Don't get in a hurry as the screens can bend quite easily. Easiest way to put them in. If I can put them in anybody can, as I have always been mechanicaly challenged The screens really make the car look
Old Mar 2, 2005 | 12:51 PM
Got mine installed with some velcro along the bottom of the screens. I left the top free of the velcro so I can easily remove the screens to clean out the area behind them.
To Z06 screen install
