Where does this go? Help!
Old Mar 2, 2005 | 06:09 AM
JTAllen79's Avatar
JTAllen79
Default Where does this go? Help!
I removed my radiator cover to paint it and a rubber block with a half inch curved slit molded in it fell out from somewhere and went bouncing across the floor. Now I'll be darned if i can figure out where it was? Can anyone help? Thanks.
Old Mar 2, 2005 | 06:19 AM
gairno's Avatar
gairno
It goes under the cover and on top of the line on the right side of the radiator. Push the cover into the opening on the rubber and it just sets there. Hope this helps.
Old Mar 2, 2005 | 06:52 AM
I agree.
Old Mar 2, 2005 | 08:25 AM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
if it what I am thinking about there are two of them.....you will see where there is a hole for the nipple of the rubber part goes through the rad cover.
Old Mar 2, 2005 | 08:43 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Here ya go, you just happen to catch me before I left for the office so I took the pic for you. Hot off the press!
Old Mar 2, 2005 | 08:49 AM
ALLEGRO's Avatar
ALLEGRO
Wow, this place is great!
One of these fell off my AE and now i know what it is and where it goes.
Old Mar 2, 2005 | 11:46 AM
Antvette's Avatar
Antvette
Veteran: Marine Corps
Is there one or two of them? I had one fall off, and I was looking for the second, but can't find it to save my life...I guess I better start looking huh?
Old Mar 2, 2005 | 11:48 AM
Cajundude's Avatar
Cajundude
I think there is only one. When I took that pic this morning I wondered the same thing. Didn't see one laying around anywhere. The only thing I know I dropped somewhere is one of the pins that hold the bridge. Haven't looked for it yet.
Old Mar 2, 2005 | 11:51 AM
iceburgh's Avatar
iceburgh
nope there is one on e each side....look at the top of the plastic rad cover you will see the holes for the nipples and the slots on the bottom for them.
I have an extra if you dont find it.
Dont really think it is needed but I have one if you do
Old Mar 2, 2005 | 04:23 PM
Dr. Dan's Avatar
Dr. Dan
Same here...It's been off for more than a year, sitting peacefully on my garage shelf. Now I can put it back...better late than never. :o
Old Mar 2, 2005 | 06:18 PM
ALLEGRO's Avatar
ALLEGRO
OK.....
I must be blind, stupid or both.
Explain to me what to look for and how to replace it. I have NOT taken off anything so it just "fell out."
HELP
Old Mar 2, 2005 | 07:19 PM
JTAllen79's Avatar
JTAllen79
Cajundude, thanks for the picture, that is exactly what I needed to see. That rubber "block" stuck on the edge. Mine even has the dimple with the metallic residue in it. Thanks man! See? Another reason to own a Vette.........this forum!
Old Mar 2, 2005 | 07:22 PM
Cajundude's Avatar
Cajundude
It's the least I could do, and you can always count on me for the least I can do.
Old Mar 2, 2005 | 07:58 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Man I've had one sitting beside me for two years!!!! I found it on the driveway one morning and haven't thrown it out. So it goes on the drivers side? Could you take a picture of it with the shroud installed? This place is great.
Old Mar 3, 2005 | 04:40 AM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
Cruise-In II Veteran
Same deal, found it after I painted the support and had it in the extra parts box...just took one person to ask....great site.
Old Mar 3, 2005 | 10:13 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Look for the other - there are two (2) of them.
Old Mar 3, 2005 | 12:02 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Mine only had one on the passenger side. Even after re-installing it after painting the cover,
I am not sure what good it does!
Old Mar 3, 2005 | 12:07 PM
Cajundude's Avatar
Cajundude
Thanks for clarifying that. The pic is of an '02. Glad I didn't start looking.
Old Mar 4, 2005 | 06:36 AM
Cajundude's Avatar
Cajundude
Put mine back together last night and this is the place. It protects the AC line from the radiator cross support. It probably keeps the two from rattling together as well.
To Where does this go? Help!
