How do I remove the front Bumper
Old Mar 2, 2005 | 11:18 AM
Bman's Avatar
Bman
St. Jude Donor '05
Default How do I remove the front Bumper
Any links or "how to's" on removing the front bumber?
Old Mar 2, 2005 | 11:23 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Send a PM to Patches. He emailed me a step by step manual but I'm at work now otherwise I would forward it to you.
EG
Old Mar 2, 2005 | 02:15 PM
Bman's Avatar
Bman
St. Jude Donor '05
Thanks eg
Old Mar 2, 2005 | 02:32 PM
z06cab's Avatar
z06cab
www.wreckedexotics.com
they show some cool ways to do it.
Old Mar 2, 2005 | 02:38 PM
ericdwong's Avatar
ericdwong
Lets see-I've had mine off a few times, you need to remove the lower air spoilers- 10 mm bolts. Then the splash guards that go between the wheel houses and the front bumper. Then reach up above the brake cooling ducts and undo 2 10 mm bolts that connect to the fender braces. Then open the hood, undo the friction fits.
Oh yeah and under where the license plate goes there are 2 plastic screw things that look like giant dry-wall anchors you need to unscrew. Then the front just lifts off. Watch the wires for the turn signal, which is routed in the passenger side. Be careful scratching the cover with 2 10mm stud things that you undid when seperating the bumper from the fender.
Old Mar 2, 2005 | 03:27 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
OMG!!!!
That sight should be banned from the internet, period!
Old Mar 2, 2005 | 04:37 PM
Bman's Avatar
Bman
St. Jude Donor '05
Thanks Eric
Old Mar 2, 2005 | 04:50 PM
ericdwong's Avatar
ericdwong
Forgot to mention- althose these should be obvious, all the bolts that go to the underside of the fascia.
Old Mar 2, 2005 | 11:06 PM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
I will be doing the same soon enough.. Thanks for the post and replies
Rain
Old Mar 2, 2005 | 11:16 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
That's some cool stuff!
To How do I remove the front Bumper
