Front and Rear Emblems
Old Mar 4, 2005 | 01:15 AM
hmsminnow's Avatar
hmsminnow
Cruising
Default Front and Rear Emblems
Hi guys. First time poster, long time reader.
I just bought a 99 FRC , and it has 50th anniversary badges on it. I'd like to go back to the stock emblems.
What is the difference between the front bumper emblem and the rear decklid emblem?
I've found relatively cheap ones on ebay, but they don't specify front or rear like I see in Vette catalogs.
Old Mar 4, 2005 | 03:32 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Congrats on your new ride We need pix ASAP! May you have miles of smiles.
The differnence I know of is the fron emblem has mounting pins (go into two holes in the nose) ... the rear one is flat. Hope this helps.
Old Mar 4, 2005 | 04:11 AM
Shylor's Avatar
Shylor
You could just take out the 50th emblem inserts. They are not connected to the emblems. Unless the emblems are gray then I could see why you would want the black ones.
Old Mar 4, 2005 | 06:47 AM
Originally Posted by MyVetteDream
The difference I know of is the front emblem has mounting pins (go into two holes in the nose) ... the rear one is flat.
That is basically the difference. The front one may have a slight curvature to it also since it has to sit on the curved front fascia. Congrats on the car too.
Old Mar 4, 2005 | 07:39 AM
SEAMOORE's Avatar
SEAMOORE
The rear one is several dollars cheaper. They charge a lot for two little mounting pins.
Old Mar 4, 2005 | 09:25 AM
BigJoe's Avatar
BigJoe
Why would anybody put 50th emblems on a '99? Kudos to you for wanting to make it right. They are not too hard to remove and replace, assuming the previous guy didn't superglue them on. Use some strong fishing line and saw through the tape holding them on.
You can get replacement at most forum stores or dealerships. And, as the above guys said, front has pins, back do not. I think the pins are so the factory can glom them on the front without worrying that they slide off before the adhesive sets. If you get two without pins, I bet the 3M tape would hold the one on the front with no problems (it holds the BSMs on...).
Old Mar 4, 2005 | 09:52 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Badges we don't need no stinking badges!!! :
I am starting to think of removing mine and get that clean look.
Old Mar 4, 2005 | 10:15 AM
jrose7004's Avatar
jrose7004
Other than your emblems, congrats on your new car and welcome to the Forum!
Old Mar 4, 2005 | 07:24 PM
hmsminnow's Avatar
hmsminnow
Cruising
thanks guys!
The badges are gray, and they don't look very good on the black car.
I have thought about going badgeless too, but it sounds like that would leave two little holes in the front of my car.
And yes, I'll try to get some pics up soon.
Old Mar 4, 2005 | 10:27 PM
Beardown3's Avatar
Beardown3
Default I actually saw a black one at the mall
recently with brand new gray emblems and it looke really sharp.
Old Mar 4, 2005 | 10:29 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Welcome.......
Old Mar 4, 2005 | 10:33 PM
Qcksilverc5's Avatar
Qcksilverc5
Default Welcome to CF --
Save the wave!!!!
Old Mar 4, 2005 | 10:37 PM
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
Just drive by England Greens house and pull it off his mailbox.......
To Front and Rear Emblems
