First post - C5 questions
Old Mar 5, 2005 | 11:32 AM
mx5_nos's Avatar
mx5_nos
2nd Gear
Default First post - C5 questions
Hi, this is my first post in these forums. I am thinking about buying a C5 but first I have several questions...
The car I will buy will be a 97-00 based on my budget. It would have to be a targa 6 speed. No auto, hardtop, or convertible.
Here are my questions:
1) Were vettes in this year range offered without any power options? ie. no power windows, locks, remote, seats, etc. How hard would it be to find a vette without these options?
2) I have read that manual C5s force the driver to shift from 1st to 4th skipping 2nd & 3rd gears. Is this true? Can this feature be disabled?
3) I have also read that all C5s have traction control? Is this true? Is the level of traction control selectable (like the C6)? If you can't select the traction control from within the cockpit, how can it be disabled and enabled?
Thanks in advance for any help you can offer with these questions.
Old Mar 5, 2005 | 11:35 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
no, yes,no
Old Mar 5, 2005 | 11:37 AM
pewter99's Avatar
pewter99
no
yes
no
Old Mar 5, 2005 | 11:42 AM
HummelS's Avatar
HummelS
Nope - all of those are base model features.
You can buy a $0.25 resistor to disable the "feature." It will also not operate above about 1800 RPM, so in normal driving (for me), it never intervenes, since I shift from 1st to 2nd at about 2K.
A button on the central console turns it on and off. In '98 and newer models, traction control is also tied to the optional "Active Handling" feature, which can also be disabled.
Old Mar 5, 2005 | 11:50 AM
blacksedan87's Avatar
blacksedan87
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
All Vettes came standard with the features mentioned -therefore it would be impossible to find one without....
It's called CAGS (Computer Assisted Gear Selection). It was designed to help GM meet the CAFE standards and avoid a gas guzzler tax. It can by bypassed by purchasing a CAGS Eliminator for about $20 - but if you drive the car like a Vette and shift a slightly higher RPM's (around 2K) - it never comes into play.
All Vettes have traction control - been on them since 1995. In 1998, Active Handling was introduced in addition to traction control. Both are controled with a single button on the console if so equipped. The JL4 Active handling can be turned off with traction control, or you can hold the button down and disengage traction control, leaving on active handling - Competitive Mode. Here's a pretty good write up on JL4 Active Handling.
http://www.idavette.net/facts/s1998/jl4k.htm
Good luck with your decision, and welcome to the forum!
Old Mar 5, 2005 | 12:17 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Welcome to the forum. The above should answer your questions. Good luck with the search.
Old Mar 5, 2005 | 12:23 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
It's called CAGS (Computer Assisted Gear Selection). It was designed to help GM meet the CAFE standards and avoid a gas guzzler tax. It can by bypassed by purchasing a CAGS Eliminator for about $20 - but if you drive the car like a Vette and shift at slightly higher RPM's (around 2K) - it never comes into play.
Perfect answer to that one
Old Mar 5, 2005 | 01:19 PM
All the C5's came with power windows and locks, and the driver's seat is power. The passenger seat could be had without power control. Like others have said, you can get a CAGS eliminator, which is very easy to install, to get rid of the 1-4 shift. Yes, all C5's have traction control. Some '98's and the '99-'00 had the option of active handling, which is a great feature safety-wise. You can get an adjustable suspension, but be forewarned that it is expensive if you ever have to repair it.
Old Mar 5, 2005 | 01:36 PM
srchief100's Avatar
srchief100
Looks like your questions have been answered So I'll just say welcome And hope that you find the car (VETTE) of your dreams that best fit's your budget
Old Mar 5, 2005 | 03:32 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
As I have a vert and it looks like all of your questions have been answered- I'll just sat Hello and welcome.
Keep reading this Forum and asking questions. Good luck on finding just what your looking for.
Old Mar 5, 2005 | 03:47 PM
c5streak's Avatar
c5streak
Looks like your out of excuses. Welcome! NOW START SHOPPING!!!
Old Mar 5, 2005 | 07:34 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
That about covers the questions, good luck in your search and welcome to the forum
Paul
Old Mar 5, 2005 | 08:19 PM
jrose7004's Avatar
jrose7004
Old Mar 5, 2005 | 09:33 PM
ALLEGRO's Avatar
ALLEGRO
Old Mar 6, 2005 | 08:59 PM
speedfreek155's Avatar
speedfreek155
Default first post
Welcome , Only been a member for a short while , but this place is like one big family , disagreements too , but when it comes down to it all Vette owners stick together.
Old Mar 6, 2005 | 09:05 PM
AllTaken's Avatar
AllTaken
I'd recommed a 97-99, just cause some '00s use oil like the '01s.
To First post - C5 questions
