Fred Beans March C5 Specials!
Old Mar 5, 2005 | 11:41 AM
Gene@FredBeans's Avatar
Gene@FredBeans
Default Fred Beans March C5 Specials!
Hello All,
This is our exciting March specials. We again, are offering parts to you at a wonderful and reasonable price. All parts 499.00 or less are 5% over dealer cost. Anything 500.00 and over is priced at dealer cost! If you have several parts totaling over 500.00 it is still 5% over dealer cost. In order to receive a part at dealer cost a single part must be 500.00 or more. Again, shipping is reasonable.
We offer this pricing on any and all Genuine GM Parts. It could be engines, accessories, parts for your Cadillac, etc. If you are requesting a price on any other part not listed here please email us or call us directly. We normally don’t have time to visit the forums during the day. You will get a faster response by email or a phone call.
You may call myself (Gene) or my assistant (Jeremy) and we will be happy to help you with all of your parts needs. Please call us at 610.495.1700, email me gculley@fredbeans.com
||--Genuine GM Engines--||
12498399 – 2002 + LS6 engine – 5030.13 (dealer cost)
12480030 – GM Performance Parts C5R block – 6247.00 (dealer cost)
89017654 – LS2 engine – 5299.23 (dealer cost)
12568950 – LS2 bare block – 906.50 + 90.00 shipping (dealer cost)
12572808 – 6.0 cast iron bare block – 620.56 + 90.00 shipping (dealer cost)
12499467 – Complete 6.0 Engine Assembly With Intake Manifold, Exhaust Manifolds, Fuel Rails, Etc.. 345 HP@ 5200RPM – 3535.00 (dealer cost)
Please ask us about the engine shipping cost directly!
||--Genuine GM Z06 Items--||
Z06 calipers – 315.80 + 15.50 shipping
Z06 front screens – 89.02 + 12.50 shipping
Z06 front brake ducts – 10295976, 10295977 – 15.97 each + 9.45 shipping
Z06 rear screens (scoops) – 10322761, 10322762 – 54.82 each + 12.50 shipping
Z06 rear brake ducts – 10425977, 10425976 – 15.70 each + 8.60 shipping
Z06 2004 shocks – 328.92 + 23.50 shipping
Z06 sway bar kit – 212.48 + 28.95 shipping
Z06 sway bar kit (insulators and bars only, no end links) – 149.40 + 26.50 shipping
Z06 front brake pads – 88952008 – 104.44
Z06 rear brake pads – 12530688 – 48.87 – shipping for front and rear is 14.50
Z06 rear differential assembly – 12572683 – 906.95 + 90.00 shipping (dealer cost)
Z06 front suspension spring – 22178729 – 374.63 + 28.50 shipping
Z06 rear suspension spring – 22188038 – 374.63 + 28.50 shipping
Z06 titanium mufflers – 750.00 each + 35.00 each shipping
||--Genuine GM HUD Setup--||
10279814 – HUD - 175.00
12198648 – Switch - 66.10
10425223 – Bezel - 16.80
Shipping for the HUD setup is 18.50
||--Genuine GM Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 - sensor – 53.70 each
25708165 - nuts – 2.39 each
Total setup is 224.36 + 15.50 shipping
97-2000 Sensors
10438853 - sensor – 82.74 each
10268439 - nut – 1.23 each (5 pack)
10268438 - washer – 1.23 each (5 pack)
Total setup is 343.26 + 15.50 shipping
||--Genuine GM Corvette Clutch Parts--||
89059282 - LS6 Slave Cylinder – 90.93
12564455 - LS6 Master Cylinder – 92.75
12570806 - LS6 Clutch Kit – 336.44
14061685 – LS1/LS6 Pilot Bearing – 8.58
Shipping for clutch is 45.00. The clutch + any other components is 55.00 shipping
||--Genuine GM LS2 Items--||
89017648 – LS2 intake manifold – 212.65 + flat fee of 5.00 shipping (dealer cost)
12570790 – LS2 throttle body – 220.50
12572174 – LS2 fuel rails – 99.36
89017587 – LS2 injector o-rings – 18.80
||--Genuine GM LS6 Intake Manifold--
88894339 - Intake Manifold Only - 400.90!!
88894339 - Intake Manifold W/Coolant Pipes And Plugs - 440.71 shipped
||--Genuine GM UltraGuard UPF 44 Oil Filters--
25329389 - UPF 44 Oil Filter
Must order in cases of 6 @ 46.25 shipped!!
||--Genuine GM Cylinder Head Bolts And Gasket Kits--||
12498543 - 97-01 LS1 Engine Head Gaskets (2) – 31.96
12498544 - 02-04 LS1 & LS6 Engine Head Gaskets (2) – 22.77
12498545 - 97-12/03 LS1 & LS6 Engine Head Bolts – 15.48 per head
17800568 – 01/04 – present LS1/LS6/LS2 Head Bolts – 14.95 per head
If you’re not sure which bolt kit to use please email us your VIN# and we’ll tell you!
||--Genuine GM Ceramic Brake Pads--||
88909667 – Front ceramic pad kit
88909668 – Rear ceramic pad kit
Both front and rear ceramic pad kits 104.74 + 14.50 shipping
||--Genuine GM Brake Rotors--||
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
Front and rear rotor sets 219.79 + 35.50 shipping
AC Delco Performance Drilled/Slotted
88926731 – RF rotor
88926732 – LF rotor
88926733 – RR rotor
88926734 – LR rotor
Front and rear rotor sets 170.26 + 42.73 shipping
||--Genuine GM T1 Engine/Suspension Items--||
T1 shocks – 556.96 + 28.50 shipping
T1 trans cooler – 877.68 + 28.50 shipping
T1 sway bar pkg with insulators and end links – 596.49 + 55.00 shipping
T1 complete suspension package – 2434.97 + 75.00 shipping (dealer cost)
T1 suspension springs 663.02 each + 28.50 shipping each (dealer cost)
||--Genuine GM Engine Parts--||
12564824 - '02 LS6 Cylinder Head (Assembly) – 695.00 (dealer cost)
12564825 - '02 LS6 Cylinder Head (Bare) – 601.05 (dealer cost)
12480110 - ASA Racing Cam - 358.79
12480033 - LS1 Hotcam Kit - 430.61
88958622 - LS6 CNC Ported Cylinder Head (Assembly) - 940.50each!! (dealer cost)
||--Helms Service Manuals--||
'97'- '04 Corvette - 124.95 shipped!!
Please Call For Any Other Make/Model Vehicle!
||--Genuine GM LS1/LS6 Fuel Rail Covers--||
12559261 - '97-'98 LH Fuel Rail Cover (Black With Red "Corvette" Lettering)
12556455 - '97-'98 RH Fuel Rail Cover (Black With Red "Corvette" Lettering)
Both FRC’s 45.68 + 12.50 shipping
12561503 - '99-'02 LH Fuel Rail Cover (Black with Red "Corvette" Lettering)
12561502 - '99-'02 RH Fuel Rail Cover (Black with Red "Corvette" Lettering)
Both FRC’s 54.54 + 12.50 shipping
12564257 - '01-'02 LH Fuel Rail Cover (Red With Black "Corvette" Lettering)
12564258 - '01-'02 RH Fuel Rail Cover (Red With Black "Corvette" Lettering)
Both FRC’s 80.60 + 12.50 shipping
Fred Beans Pontiac Buick GMC Terms And Conditions Of All Sales:
We reserve the right to change the price of any part at any time and/or refuse to sell a part for any reason at any time. Price changes that can be made through the month are final and all sales before and after the price change are final. We will accept no returns after 30 days and all boxes or packages must be in the same condition as which they were received. If a package is received in anything other than perfect manner, please call and note upon receipt. Anything noted after the fact is the responsibility of the buyer. All returns are subject to a 20% restocking fee and/or a fee for unacceptable boxing or packaging. We reserve the right to change the terms and conditions of a sale at any time for any reason.
Old Mar 5, 2005 | 01:23 PM
Some great prices Gene. I may have to give you a call on Monday.
Old Mar 6, 2005 | 08:55 AM
Gene@FredBeans
Thanks..
Give us a call. We would appreciate the business.
Gene
Old Mar 6, 2005 | 09:46 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Thanks for the great price, Gene
Old Mar 20, 2005 | 10:11 AM
Gene@FredBeans
Give us a call or email guys!
Gene
Old Mar 20, 2005 | 10:16 AM
speedfreek155's Avatar
speedfreek155
E-Mail sent
Old Mar 20, 2005 | 01:44 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Great prices as usual. Could you give me a price on a radiator cover?
Old Mar 20, 2005 | 02:04 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Hey Gene,
Do you accept paypal, or do i just call up Monday and talk to you then?
Mike
Old Mar 20, 2005 | 02:06 PM
F.J.B.'s Avatar
F.J.B.
From: Vette Doctors Performance RX450 - 466RWHP !!!
Hey Mike...
I called up and used a CC and was done in 5 minutes. Easy to deal with. Got the Z06 Sway bars from them!!!
Nice pics saturday!!!!!
B
Old Mar 20, 2005 | 04:37 PM
silverminevette's Avatar
silverminevette
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '03-'04-'05-'06
E mail sent!
Old Mar 20, 2005 | 08:08 PM
Freestyler's Avatar
Freestyler
Holy Crap Gene
terr-rif-ic pricing... the hud stuff... is that ALL i would need for a retro fit to a 98 C5? (does it include the controls that mount into the dash opposite the DIC controls?)
awesome
FreeStyler
PS -what about RunFlats - GenII (C6) can you get them in C5 (18/17) sizing and what would the costs be?
if you cant get them to us, can you advise on their dealer price anyways so we can be on the look out for what a good deal might look like?
Old Mar 21, 2005 | 06:46 PM
Gene@FredBeans
Originally Posted by Freestyler
Holy Crap Gene
awesome
FreeStyler
On a 98 you'd need a HUD enabled cluster and an 11 pin wiring connector if I remember correctly. Most salvage yards can help you with the cluster. There are 2 gentlemen on here selling the connectors. The problem with us selling tires is that by the time you add shipping I'm more expensive than anyone else.
Gene
Old Mar 21, 2005 | 07:39 PM
CUlookin's Avatar
CUlookin
Bought my calipers through Gene! Great transaction!
Old Mar 22, 2005 | 03:25 PM
Freestyler's Avatar
Freestyler
Cheers Gene
hey... while we have your ear ...
there is a thread on the C6 board that is talking about swapping out the LS1 engine with a LS7 crated engine -- due in August -
can you keep an eye out for details and pricing?
http://forums.corvetteforum.com/sho...d.php?t=1044752
Most Powerful Small-Block Ever - Available in a Crate
FOR RELEASE: 2005-03-22
CONTACTS
DETROIT - Chevrolet unveiled the 2006 Corvette Z06 at Detroit's North American International Auto Show in January, and now GM Performance Parts is unveiling the crate engine version of the LS7 engine that powers it. This latest Z06, billed as "the fastest, most powerful car ever offered by Chevrolet and GM," has enthusiasts looking for that kind of power in a crate engine. GM Performance Parts is ready to end that search as it offers the LS7 (P/N 17802397) at GM dealerships and Authorized Centers, nationwide in August.
FreeStyler
Old Mar 22, 2005 | 07:13 PM
Gene@FredBeans
Right now all there that exists is a part number in the system. There is no price, no warehouse assignment and no stocking info.
When these come out be rest assured we'll be one of the first to have it and the one's with the best price.
Gene
Old Mar 27, 2005 | 10:07 AM
Gene@FredBeans
Happy Easter All.
Please send me an email or call if you need anything.
Gene
Old Mar 27, 2005 | 10:29 AM
GR8-LIFE's Avatar
GR8-LIFE
Damn! Check out the price on the LS6 Clutch kit!
Old Mar 27, 2005 | 10:32 AM
GR8-LIFE's Avatar
GR8-LIFE
Holy Crap Gene
awesome
FreeStyler
I have a 99 and did not purchase the hud option. Wouldnt you have to also cut a hole in the dash? What would the R&R be on doing a retro fit?
To Fred Beans March C5 Specials!
