Battery question ... no not that question!!
Old Mar 5, 2005 | 05:29 PM
mike1944's Avatar
mike1944
Default Battery question ... no not that question!!
Is there supposed to be a bracket or something that holds the battery down? I guess mine is bouncing around and for the second time in 6 months has loostened the battery cable connections to where the car wouldn't start. Is the a bungee cord or something that could be used? Thanks for the ideas.
Old Mar 5, 2005 | 05:32 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
There is a stock plastic piece that holds it down on the front side of the battery, on the bottom
Old Mar 5, 2005 | 05:33 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Mar 5, 2005 | 05:37 PM
mike1944's Avatar
mike1944
I saw that. Did try to tighten it down on my Optima red. But wouldn't hold. Wasn't sure that was what it was for. Will give it another shot.
Old Mar 5, 2005 | 05:47 PM
Scratch's Avatar
Scratch
I believe the Optima uses an adaptor to take up the slack from the stock holder, different sizes of batteries.
Old Mar 5, 2005 | 06:09 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Old Mar 5, 2005 | 06:18 PM
mike1944's Avatar
mike1944
I called the place that installed the Optima and they said ..."oops sorry, bring it in and we'll install the brackets"
So thanks for the help.
Old Mar 5, 2005 | 07:26 PM
Autoworker's Avatar
Autoworker
Optima calls it an adapter puck, and it forms around the center cell to hold the battery down. Replaces the factory puck. If you bought the battery new, they should have supplied you with one. If you bought the battery used, go to Optima's website and ask them to send you one.
Old Mar 5, 2005 | 07:37 PM
JDAN1930's Avatar
JDAN1930
I used my original battery hold down when I replaced with the "Red Top" - It has held for a month now
Old Mar 5, 2005 | 09:21 PM
hep's Avatar
hep
My original stock bracket has been on for 2 months with the red top,no problems. Hep
Old Mar 5, 2005 | 11:21 PM
Cirrus8's Avatar
Cirrus8
I have the Optima 75/35 battery in a 2001 coupe and the OEM puck holds it down with no problems.
To Battery question ... no not that question!!
