Front air spoiler
Mar 6, 2005 | 06:39 PM
Front air spoiler
Guys i just discovered that my front Cente air spoiler is missing and im wondering should i replace it or will it be fine without it... someone mentined it will keep the car cooler with the spoiler there and other said dont worry about it...
Me personally its a plus not having it there b/c it would scrape on the driveway all the time even when i pulled out sideways...
should i replace or leave as is..
Mar 6, 2005 | 06:43 PM
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
It's there as part of the car's aerodynamics. If you go to the parts section and ask, you an get one cheap. Even new, they're only a few bucks. I would. Just my $.02
Mar 6, 2005 | 06:44 PM
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
One of the reasons it is there is to deflect air to the radiator. They are designed to scrap and are cheep enough to replace. If it were me I would replace it.
Mar 6, 2005 | 06:46 PM
From: hamilton nj "Life's tough......It's even tougher if you're stupid."-John Wayne
Quote:
I took mine off and the car over heated at highway speeds going to Long Island last March
Mar 6, 2005 | 06:53 PM
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
The C5 is a "bottom breather" and the spoiler underneath is an integral part of deflecting air up into the engine compartment...it needs to be there.
Mar 6, 2005 | 07:04 PM
Absolutely replace it
Mar 6, 2005 | 07:43 PM
Quote:
Mar 6, 2005 | 07:59 PM
You should replace it .... yesterday if possible!
Mar 6, 2005 | 10:45 PM
I'd replace it. It is designed to redirect the air up into the radiator cavity.
Mar 7, 2005 | 05:50 PM
St. Jude Donor '03-'05-'06-'07-'09
About $35 from GM and include the metal support...for a '98...just replaced mine. It too disappeared. Never had any overheating issues,
Mar 7, 2005 | 05:52 PM
Quote:
the dealer here in so cali wants 69 for it...
Mar 7, 2005 | 06:07 PM
2017 C7 of the Year Finalist
St. Jude Contributor
Replace it NOW. Very important part of your car.
Don't worry about it scraping, it's hinged just for that reason.
Mar 7, 2005 | 06:11 PM
this is what im looking for..
so why is it so important to have on the car except aerodynamics?? thanks
Mar 7, 2005 | 06:17 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Quote:
Jetspeedz..i think JDs sums it up perfectly
Mar 7, 2005 | 06:21 PM
Quote:
ok thanks guys...
IS there anywhere online i can buy this cheaper then spending 70 for it here.. thanks if not ill just get it from the stealership here..
Mar 7, 2005 | 06:26 PM
St. Jude Donor '06-'07-'08
Try GM Parts Direct, gmpartsdirect.com
Mar 7, 2005 | 06:28 PM
can anyone put up a link to a supplier so we can go purchase one? btw, is it difficult to install it?
Mar 7, 2005 | 06:30 PM
CI 6-7-8-9-10 Veteran
mine was 65 at my dealer, fair imo
Mar 7, 2005 | 06:32 PM
Quote:
does it require any bolts or anything?
