Vert Owners -- Please step in...
Old Mar 7, 2005 | 11:13 AM
ArmyVette's Avatar
ArmyVette
Default Vert Owners -- Please step in...
What are you using to fill the space behind your seats and under the vert top's storage compartment lid?
I need something there to keep the wind out but that will still let the rear speakers be heard. What I've seen so far are sound blockers that are inserted into that space.
Any suggestions?
Old Mar 7, 2005 | 11:18 AM
WKMCD's Avatar
WKMCD
I'm not real sure what you are talking about but I'm now waiting for the delivery of my partition which seperates the "trunk area" from the area required when the top it down. It works great to reduce road/exhaust noise.
Old Mar 7, 2005 | 11:19 AM
ROADAPPLE's Avatar
ROADAPPLE
I'm using a partition made by one of our memberrs CRAZYC5COWBOY. but that devides the trunk from the storage compartments.
I have not seen a devider between the passenger and storage compartment.
Old Mar 7, 2005 | 11:22 AM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Many around here use various partitions. Home made or from vendors. I have not changed mine. Sometimes I run with the trunk open about an inch. With a home made mod. This allows the air to flow through. While topless I just turn the radio up a little more. Enjoy
Old Mar 7, 2005 | 11:23 AM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
http://www.exoticvette.com/Exotic%20Vette/partition.htm
http://forums.corvetteforum.com/show....php?t=1023263
Dan is a great guy to work with
Old Mar 7, 2005 | 11:32 AM
ArmyVette's Avatar
ArmyVette
I've already got the trunk partition on order from Dan.
That partition, however, separates the top storage area from the trunk.
There is still the issue of the open space under the storage compartment lid and the front of this partition.
Here's is what one vendor is selling. Was wondering if anyone has seen anything else that might plug this hole but still allow you to hear the rear speakers.
WCC two piece set
and
One piece set
Old Mar 7, 2005 | 11:39 AM
Elite Engineering
Supporting Vendor
St. jude Donor '14
WCC two piece set
and
One piece set
I would think Dan's partition would do everything and more that these two products offer.
Old Mar 7, 2005 | 01:04 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
When the wind noise bothers me too much I put my windows up about 1- 1.5 inches. I've found that most of the wind noise is from the air hitting the upper seatbelt mounts. Try it.
Old Mar 7, 2005 | 01:07 PM
ArmyVette's Avatar
ArmyVette
Good advice. Will try that as soon as the temperatures permit!
Old Mar 7, 2005 | 01:08 PM
NCSU SEE 5's Avatar
NCSU SEE 5
From: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
St. Jude Donor '05-'06-'07
Originally Posted by Elite Engineering
Love mine. Dan's partition is top quality.
Sorta like Elite's stuff
Old Mar 7, 2005 | 01:26 PM
gunnygotavet's Avatar
gunnygotavet
those partitions look like you could make them has anyone tried. I think some 1 inch foam would work and then cover them with carpet and velcro on
Old Mar 7, 2005 | 01:34 PM
mopac's Avatar
mopac
WCC two piece set
and
One piece set
I have the wcc two piece set and can tell you it keeps stuff ok in the trunk and does'nt have much effect on the rear speakers, but with the top down stuff in the cockpit still blows around once you reach 90 - 100 mph. I just purchased the vette net and can't wait to try it once it warms up some they claim it eliminates the cockpit buffeting
Old Mar 7, 2005 | 03:48 PM
2003vert's Avatar
2003vert
You will love the vett net it is great!
Old Mar 7, 2005 | 04:47 PM
Corvette Tommy's Avatar
Corvette Tommy
St. Jude Donor '08-'09
That is a great solution.
Old Mar 7, 2005 | 04:55 PM
pinskiC5's Avatar
pinskiC5
Ummm...maybe I'm missing something here, but it's a convertible.
You drop the top, you ought to expect it to be a bit breezy when you're blasting down the road at 65-75mph.
But maybe that's just me...I kinda like it!
Old Mar 7, 2005 | 05:03 PM
Sportsdude's Avatar
Sportsdude
Old Mar 7, 2005 | 06:10 PM
5150 BRD's Avatar
5150 BRD
I had the Sound Killers on my vert. They looked nice but there are drawbacks. Not only do they kill the sound from the rear but also the rear speakers. Also, they are a pain when you raise or drop the top as you have to adjust them because they attach to the vert cover.
I decided to try the partition from Dan @ Exotic Vette as mention above and really like the product better that the Sound Killers. The only issue I have had so far is the velcro that attached to the horizontal bar that hold the partition has come loose. Not a big problem but I will have to re-glue it. I still recommend it highly.
Hope that helps.
To Vert Owners -- Please step in...
Old Mar 7, 2005 | 07:35 PM
ruandlou's Avatar
ruandlou
Installed one i picked up from Dan @ Exotic Vette - very pleased -kills the noise and looks good too!
Old Mar 7, 2005 | 08:55 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Dan @ Exotic Vette
Old Mar 7, 2005 | 10:21 PM
Red Vert 02's Avatar
Red Vert 02
