Any Tall Vert Drivers?
Old Mar 7, 2005 | 08:42 PM
BlownV6's Avatar
BlownV6
Default Any Tall Vert Drivers?
As in Tall i mean around 6'5". Friend of mine is going to look at a 99 Vert but he's unsure if he'll be able to fit. Vert drivers.. How tall are you and how much headroom do you have?
Old Mar 7, 2005 | 09:15 PM
drmgoat's Avatar
drmgoat
6'4", 250 lbs. It's a nice fit. I look out through the windshield not over it and my seat isn't all the way back. Plenty of headroom with the top up. My advice is to go sit in one.
Old Mar 7, 2005 | 09:27 PM
98vert6spd's Avatar
98vert6spd
6'2 190
plenty of room for 3 more inches
i have the seat all the ay back but its cause im from the streets
GGGGGGGGGGGG G-UNIT
Old Mar 7, 2005 | 10:09 PM
BlownV6's Avatar
BlownV6
Thanks guys. He'll be very happy to hear this. Has his heart set on a Triple Black Vert
Old Mar 8, 2005 | 12:02 PM
wamara's Avatar
wamara
Cruise-In II Veteran
I'm just shy of 6'6", and my head brushed the liner on 01+ verts (annoying sensation). Your friend may be in luck with the 99, as the tops didn't have as many layers (changed in '01), so it should be thinner and hopefully consequently has more headroom. As for comparing heights, I've found that everyone's body configuration (length of torso vs. legs, etc.) is so different that you just have to try it for yourself to see, and not necessarily rely on someone else's experience. Hope it works out for him !!
Old Mar 8, 2005 | 12:08 PM
D.Brawl's Avatar
D.Brawl
My brother is 6'4" and drove an '00 vert with no problems. He and his wife would take it on long vacation trips over their Olds. I'm only 6'1" so I never had any problems, either.
Old Mar 8, 2005 | 12:18 PM
thibo's Avatar
thibo
I'm 6'4 and weigh 220. I own an 01 vert. No problems here with leg room or head room.
Old Mar 8, 2005 | 12:19 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
If the vert doesn't fit him have him try a coupe with the glass top - I think it has an inch or two more headroom than the vert
Old Mar 8, 2005 | 12:41 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
6'5 - 315 .. it is tight with the top up, but I do fit (you have to adjust the seat correctly)
Old Mar 8, 2005 | 03:50 PM
drsuperman's Avatar
drsuperman
6'5" 230 Fit fine in mine
Old Mar 8, 2005 | 04:20 PM
KC Vette's Avatar
KC Vette
Cruise-In I Veteran
6'4' amd 225, no problem either..
Old Mar 8, 2005 | 05:55 PM
dankhts's Avatar
dankhts
6'4" and 225 lbs, or, as we say in Canada, 196 cm and 102 kg. I fit just fine with lots of room, just wish the pedals were a little farther away in my '02 'vert.....
Old Mar 8, 2005 | 06:01 PM
RaVolt's Avatar
RaVolt
It's going to depend on if most of his height is in his legs or in his torso. I'm 6'5" and long in the torso. When I get in a vert, my head does rub against the liner.
As such, I have a coupe for my daily driver. I would like to get a vert but I would only use it when I could drive with the top down.
Old Mar 8, 2005 | 08:45 PM
NSTG8R's Avatar
NSTG8R
not very tall (6'1) ... i have lots of room.
Old Mar 8, 2005 | 09:49 PM
Qcksilverc5's Avatar
Qcksilverc5
Originally Posted by 98vert6spd
6'2 190
GGGGGGGGGGGG G-UNIT
6'2" 200 lbs---lots of headroom and legroom for me!
Old Mar 9, 2005 | 12:46 AM
pdd000's Avatar
pdd000
5'9" 200ibs fit great but its a bitch to get in and out of the car with the top up
Jeffyvette's Avatar
Jeffyvette
6'4" 270 fit fine
To Any Tall Vert Drivers?
