Help with Code
Old Mar 8, 2005 | 11:31 AM
sasunlover's Avatar
sasunlover
Default Help with Code
Coming to work this morning, the check engine light came on. I checked the codes and only found one - PCM P0410 - Both History and Current. What does this mean and what action if any should be taken? I cleared the code and so far, the light has remained off.
Old Mar 8, 2005 | 11:39 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
P0410 AIR System --- I think it has to do with the air pump. Others will chime in with more.
Old Mar 8, 2005 | 12:05 PM
rickko's Avatar
rickko
Here's a site I've found helpful to begin decphering OBD II codes:
http://www.diagnosticdialog.com/LookupCode.asp
For this code all it says is 'air system'
..rickko..
Old Mar 8, 2005 | 01:32 PM
sasunlover's Avatar
sasunlover
Default Codes
Thanks. Drove to lunch and back and the light is still off. Anyone have more info?
Old Mar 8, 2005 | 01:41 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The two web sites that I looked at didn't offer any more information than what you've already received.
http://www.stengel.net/diccodes.htm
http://www.corvettedoctor.com/Codes_Page.htm
But I got this by doing a Google search......
P0410
1. That is dealing with the AIR system. Possibly a check valve.
Circuit Description:
An AIR pump is utilized on this vehicle to lower tail pipe emissions on start-up. The PCM supplies a ground to the AIR pump relay, which energizes the AIR pump.
The PCM monitors the HO2S voltages to diagnose the AIR system.
During the AIR test the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for BOTH banks did not respond as expected during the tests, DTC P0410 sets and your looking at a pretty amber SES on your dash.
Tests - Check AIR pump fuse. Inspect for intermittent shorts to ground or connections, if the AIR pump functions properly. Inspect the circuits for a short to ground between the AIR pump fuse and the AIR pump relay. Also inspect the circuit for a short to ground between the splice and the AIR solenoid valve.
As an option, you could consider getting that deleted through LS1 edit (or comparable software).
Hope this helps.....
Old Mar 8, 2005 | 09:37 PM
sasunlover's Avatar
sasunlover
Default Help with codes
Thanks guys. Now if I only knew where the air pump is and what it looks like, as well as this relay. This does help tho. I appreciate it. The forum is great as always.
Old Mar 9, 2005 | 01:31 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Keep us posted on what you find.
To Help with Code
