Velocity Stack? Yes Or No.
Old Mar 9, 2005 | 01:24 PM
empty pockets's Avatar
empty pockets
Default Velocity Stack? Yes Or No.
I Just Installed A New Hallteck Intake, Someone Told Me I Should Get The Velocity Stack That Goes Inside The Throttle Body To Smooth Out The Air Flow. (10 Hp Gain??) Yes Or No Thanks For The Help.
Old Mar 9, 2005 | 01:25 PM
BlownV6's Avatar
BlownV6
No. Waste of money
Old Mar 9, 2005 | 02:45 PM
Cajun99's Avatar
Cajun99
Originally Posted by empty pockets
Someone Told Me I Should Get The Velocity Stack...(10 Hp Gain??)
z06cab's Avatar
z06cab
I gained about an extra couple hundred horse with it...
but that was coupled with a twin turbo kit...so that may have had an effect.
Old Mar 9, 2005 | 02:48 PM
VetteSiNz's Avatar
VetteSiNz
High performance hood seal gives you more HP than Velosity stack.
Old Mar 9, 2005 | 02:54 PM
vmspionage's Avatar
vmspionage
It's safe to say that your friend is a freakin' moron.
Just kidding, but seriously those things don't do jack.
Old Mar 9, 2005 | 02:57 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Ouch !
Old Mar 9, 2005 | 03:54 PM
Red Rag Top's Avatar
Red Rag Top
Originally Posted by BlownV6
No. Waste of money
Old Mar 9, 2005 | 04:02 PM
saalanghae's Avatar
saalanghae
No No No You have to get coolant by pass kit with the velocity stack to get it work right. If you dont' you get no HP gain. If you do you gain around 12.34765 HP at idle.
Old Mar 9, 2005 | 04:05 PM
jdetar's Avatar
jdetar
I heard those Type-R stickers add as much as 50RWHP too!
Old Mar 9, 2005 | 04:11 PM
NitrousMan's Avatar
NitrousMan
No. Waste of money
Old Mar 9, 2005 | 05:22 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
That's Type-R stickers are only good for 21rwhp
Old Mar 9, 2005 | 05:35 PM
Don't waste your money.
Old Mar 9, 2005 | 05:51 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
You need bigger Type-R decals EG! I have heard the 48" ones deliver an extra 38RWHP!
Old Mar 9, 2005 | 07:52 PM
big hoss 98C5's Avatar
big hoss 98C5
Old Mar 9, 2005 | 08:11 PM
vetterlatethannever's Avatar
vetterlatethannever
Another emphatic no!
Old Mar 9, 2005 | 09:47 PM
TGBEATY's Avatar
TGBEATY
Have any of you actually tried it or are you just assuming it doesn't work? Anyone dyno before and after??
To Velocity Stack? Yes Or No.
Old Mar 9, 2005 | 09:57 PM
Poptops's Avatar
Poptops
High performance hood seal enhanced by the reduction in the drag coefficient which is modified exponentially (if traveling north to south) or geometrically (if traveling east to west) with coats of Mequire's NXT.
Can you hear me player?
Old Mar 9, 2005 | 10:00 PM
KamPow3r's Avatar
KamPow3r
Originally Posted by Cajun99
Old Mar 9, 2005 | 10:06 PM
ArKay99's Avatar
ArKay99
I did. I also tried it with my stock maf and a granatelli. Actually I tried all those combos. The best all around hp and tq was... With the stock maf and no Velocity Stack. Actually, the velocity stack had the same numbers on each run. It actually MAY do something on a stock car and at speed, but sitting on a dyno it didn't do squat for my car. BTW, it was stock except for headers, xpipe and exhaust. Also had an LS1 manifold.
BTW, I went from 337rwhp to 413 rwhp with the performance hood seal, the throttle body bypass, a smooth coupler, Zaino, and 20% tint.
