Painting calipers experience
Old Mar 10, 2005 | 12:45 PM
rickko's Avatar
rickko
Default Painting calipers experience
After reading some of the threads like this I decided to tackle the job but which product to use?
I bought the Duri-color Caliper Paint kit for about $16 from Kragen AND a half-pint of Rustoleum 'Sunrise Red' from Home Depot (1 pt. $3.49) along with an Artist Brush kit from HD ($3.97).
I bought both because I wasn't sure which color I was going to like.
I started with the Duri-Color RED and found it to have more purple in it. When done it seemed more like it matched the color of the rear marker lens.
Then on the other side of the car I tried the Rustoleum. Now that's RED, in my opinion. It more matches the color red in the Corvette logo flags and is closer to my personal liking. Its definitely a brighter red than the Duri-Color red.
Good thing I bought the extra artist brushes kit from HD because after I finished painting the 1st caliper using the Duri-Color brush that came in its kit I pulled all the brush bristles out of the brush cleaning it! Cheap.
I'm going to do one of the front calipers today. I will probably try both techniques to remove the excess color on the CORVETTE letters (ie. laquer thinner on a rag, and fine sand paper on a block).
Not being experienced with painting I found the directions in the DuriiColor kit to be best regarding applying 2nd and 3rd coats. That is, to wait about 15 to 20 minutes between coats.
Unfortunately I didn't do that with my 1st caliper so the application doesn't look quite as smooth as my 2nd. But I'm going to sand it down and apply a coat of Rustoleum over the DuriColor to get that brighter red look anyway . That should fix it.
Boy, painted calipers sure look great!
..rickko..
Old Mar 10, 2005 | 02:07 PM
rwlc5's Avatar
rwlc5
If you use the Rustoleum you are going to have to wait longer than 20 minutes for it to dry. I used the rustoleum and applied it with a 1 inch foam brush. I let it dry overnight and applied 4 coats. I did the brackets in rustoleum black and did the letters on the fronts in black also. They turned out great and still look good 2 years later. Good luck.
Old Mar 10, 2005 | 02:11 PM
jrose7004's Avatar
jrose7004
I used VHT paint but my only trouble is brake dust that I can't seem to get off so the calipers look too dark!
Old Mar 10, 2005 | 02:20 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Pics
Old Mar 10, 2005 | 02:39 PM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
try the tirerack caliper painting kit they are $38 and I saw pics on someones car whos on here im sure hell post them... color matches torch red perfectly and looks amazing.. i think i am goin to do that.
Old Mar 10, 2005 | 02:41 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
Pep Boys (don't recall the product name) has a caliper paint that works great...color red is "Torch Red", very bright Went on great. I tried VHT in the past, looked darker and got dirty looking after awhile, thus leading to the re-paint using the Pep Boys paint.
Old Mar 10, 2005 | 02:42 PM
Z0Sick6's Avatar
Z0Sick6
St. Jude Donor '05
scratch for the pep boys paint did you take the calipers off? was it spray paint or put on with a brush?
Old Mar 10, 2005 | 02:48 PM
Scratch's Avatar
Scratch
Spray paint, I removed the wheel and masked critical areas.
The paint still has a wet look, covered great (after cleaning calipers) I was impressed
Old Mar 10, 2005 | 02:56 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I think you're talking about me.....
Old Mar 10, 2005 | 02:59 PM
rickko's Avatar
rickko
Originally Posted by c5BlackBeauty
Pics
I thought I'd wait till I get the fronts done. But maybe I should take the two different colors now. Don't know how much of a difference will be seen considering quality of camera and lighting etc. but I could give it a try.
Here are pics of each. There are too many variables to be sure you are seeing how they look; camera, compression, your PC monitor, etc. but maybe you can tell a difference.
1st one is Duri-Color 'Red'
2nd is Rustoleum 'Sunrise Red'
..rickko..
Old Mar 10, 2005 | 05:26 PM
Good luck with the rest of the calipers. Just a suggestion, try using an exacto knife to scrape the paint off the letters. It works just fine.
To Painting calipers experience
