what size tires?
Old Mar 11, 2005 | 04:31 PM
b98's Avatar
b98
Default what size tires?
I just bought new wheels 18x8.5 / 19x10. for my 98 vette. what size tires would be best to keep everything with-in specs.
Old Mar 11, 2005 | 09:54 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
If you want to retain close to stock OD and F/R ratio, your choices are somewhat limited by that 8.5" rim width up front. Plugging sizes into the online tire size calculator and comparing them against stock, it looks like 245/40-18 & 285/35-19 are a good match.
Old Mar 11, 2005 | 11:18 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Originally Posted by BW1
If you want to retain close to stock OD and F/R ratio, your choices are somewhat limited by that 8.5" rim width up front. Plugging sizes into the online tire size calculator and comparing them against stock, it looks like 245/40-17 & 285/35-19 are a good match.
think them 17's will stretch enough for those 18 rims
Old Mar 12, 2005 | 12:51 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
If he tries really, really hard they will.
Old Mar 12, 2005 | 10:25 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Just remember to keep as close to the diameter (front-back) ratio as stock, otherwise it can effect Active Handling.
To what size tires?
