Performance Axle Question
Old Mar 11, 2005 | 04:57 PM
mike85mph's Avatar
mike85mph
Default Performance Axle Question
Friend of mine looking at a used Vette - 2002 I think. the owner doesn't know if it has the performance axle or not (an A4 transmisison - I think the optional performance axle is 3.15). Should be able to tell form the VIN, right, or is there a different code somewhere that shows all the options? How can he tell if it has the axle he wants?
Old Mar 11, 2005 | 05:05 PM
HummelS's Avatar
HummelS
Look at the sticker on the inside of the glove box door; It will show G92 if it has the 3.15 gears.
Old Mar 11, 2005 | 05:09 PM
That's the place. Hopefully it has the upgraded axle.
Old Mar 11, 2005 | 09:01 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Also if the 02 has the Z51 suspension the 3.15 performance ratio axle was a required option with the A4.
Old Mar 12, 2005 | 12:20 AM
Mitch C's Avatar
Mitch C
Old Mar 12, 2005 | 07:05 AM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
Old Mar 12, 2005 | 07:26 AM
Patman's Avatar
Patman
You can also tell by the rpms at 70mph. If it's around 2000rpm, it's 3.15s. If it's closer to 1500rpm, it's the 2.73s.
Old Mar 12, 2005 | 07:46 AM
mowton's Avatar
mowton
Everyone has answered your question so I will just post an opinion.
Using the words "performance axle" and "3:15" in the same sentence is an oxymoron! Really wish they would of added a bit more rear in the A4 from the factory.
Good luck
Old Mar 12, 2005 | 07:53 AM
mowton's Avatar
mowton
Default Best of both worlds and a small thanks.....
Originally Posted by Patman
You can also tell by the rpms at 70mph. If it's around 2000-2200, it's 3.15s. If it's closer to 1500rpm, it's the 2.73s.
My MN6 tach's at 1500 at 70 MPH as well, with the stock 3:42's. All the performance associated with neck breaking acceleration and 28 miles to the gallon on the open road. I think Dave Hill and Chevy hit a homerun on this setup! Thanks Dave
Old Mar 12, 2005 | 08:01 AM
BlownV6's Avatar
BlownV6
A .50 6th gear ratio will do that.
Old Mar 12, 2005 | 08:44 AM
mowton's Avatar
mowton
Now, if they could get it down to .00
Old Mar 12, 2005 | 10:40 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
That's why I NEVER use 6th. If you read the specs on these cars, top speed is reached in 5th gear...WAY too much overdrive in 6th!!
Old Mar 12, 2005 | 01:22 PM
gtzy's Avatar
gtzy
I stopped last nite to look at an 02 on dealer lot,,naturally it was locked up,,when looking under neath,saw there was a metal tag on the right rear of the differential with the ratio [2.73]printed on it.
Old Mar 12, 2005 | 01:44 PM
Mike Mercury's Avatar
Mike Mercury
But it is "performance" to this guy:
check out my web page on determining rear axle ratios on C5's:
http://mikemercury.home.att.net/ratio.htm
Old Mar 12, 2005 | 03:35 PM
mowton's Avatar
mowton
Tim,
I agree. Your website is . especially like the automatic car cover. quite ingenious. what happens if you close the door without the car in the garage? Must look strange!
Ed
Old Mar 12, 2005 | 04:33 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Old Mar 12, 2005 | 04:51 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
There is one surefire way to determine if you have the 3.15 when the glovebox sticker is gone.
Place the gear selector in 3rd and get it up to 75mph. The tach will read 3150rpm for the 3.15 or 2730 for the 2.73. You can't get anymore exact than that, it works every time.
Old Mar 12, 2005 | 04:53 PM
Mike Mercury
it hovers about 1 foot from the floor... and it does look weird
it's still working perfectly - now going on 4 years (knocking on wood - for luck)
To Performance Axle Question
