Ceramic coated headers
Old Mar 12, 2005 | 10:41 AM
Vette Freak's Avatar
Vette Freak
Senior Member
Cruise-In V Veteran
Default Ceramic coated headers
Just orderd headers.... Do you need to do this to your headers???
will everything be too hot if not??
HELP!!!
Old Mar 12, 2005 | 11:24 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
It's more personnel preference than anything. I had mine Jet-Coated primarily for the looks, with the added benifit of a little less heat transfered to eng. compartment.
Old Mar 12, 2005 | 11:47 AM
Vette Freak
Senior Member
Cruise-In V Veteran
What will it look like with them coated???
Old Mar 12, 2005 | 11:56 AM
Z06-JIM's Avatar
Z06-JIM
Here's a pic of my LG Longtubes from underneath.
Old Mar 12, 2005 | 12:17 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
The coating really does make them look a lot better. Percentage wise how much more or less temp is transfered or does anyone know? I would do it just for the looks.
Old Mar 12, 2005 | 12:18 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
If your headers are made of mild steel (which many are) and not stainless steel, then it IS a good idea to get them ceramic coated. When they ceramic coat headers they are done inside and out.
The benefits to ceramic coating.
1) As you've seen above in Z06-JIM's reply, they look much nicer
2) It will help reduce heat in the engine compartment.
3) It will aid in the flow of exhaust gasses through the pipes.
4) It will keep mild steel pipes from rusting out from the inside out.
Number 4 is important to steel headers. You will get many more years of use out of the headers with the coating.
Old Mar 12, 2005 | 01:59 PM
Vette Freak
Senior Member
Cruise-In V Veteran
Thanks for everyones help
Old Mar 12, 2005 | 02:19 PM
Those headers on Z06-JIMs car look great.
To Ceramic coated headers
