Memory seats?
Old Mar 13, 2005 | 06:47 PM
DEciiBel's Avatar
DEciiBel
Default Memory seats?
I just purchsed an 01 with memory. No manual included in sale. Tried GM link (no Luck) and have a bid on ebay for a manual. I'm trying!
How do I operate the sucker. It's making me nuts.
A psychiatrist or immediate guidance is needed.
Old Mar 13, 2005 | 06:52 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
First, take a DEEP breath, then,
Sit down in the Vette (drivers side please), then
Adjust the seats to the desired comfort level needed, then
push the Memory 1, or 2, on the drivers door (above the Window buttons) untill it flashes twice.
Stop, take a DEEP breath, and
now for the other option(s) set up:
with the key on, push the "Option" button (it is om the right side area behind the steering wheel), then
scrool through the menu wutil you come to the item you desire to program, then
set up the specific option to your personal requirements,
then
Go to the refrig, get a cold one, and sit down, since after all that hard work youll need the rest.
Old Mar 13, 2005 | 07:03 PM
6 Shooter's Avatar
6 Shooter
Set your seat, left/right mirrors, telescopic steering wheel, radio stations and heads up where you want them. Push Memory button until it flashes twice, now it's programmed. For the setting to return to their programmed positons, you must lock and unlock your Corvette.
Hope this helps.
Later . . . . . .
6 Shooter
Old Mar 13, 2005 | 07:13 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
PM me with you email address and I will email a 2001 manual in pdf format.
Old Mar 13, 2005 | 07:16 PM
KOMPNS8's Avatar
KOMPNS8
hold mem1 and mem2 at the same time to set mem3!!! it's like a bonus supermario level at your fingertips!!!
Old Mar 13, 2005 | 07:22 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
what they said!
The one thing to remember is to press the unlock button as you approach the Vette. Otherwise the memory won't work. Also remember there are two different key fobs. Each one works independently, so don't use the #2 fob and wonder why your settings are different.
Good Luck
Old Mar 13, 2005 | 09:27 PM
Freestyler's Avatar
Freestyler
dont forget to try the side adjusters and the font-of-chair-lift, while rear-of-chair-decline -- set your most romantic cd into play and bring the temp down to a nipple inspiring degree and lock in Mem2-Mem3
Just add your S/O and your in business
FreeStyler
Old Mar 14, 2005 | 01:16 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Do the Zilla thing. It's best to have one on your computer anyway.
To Memory seats?
