Top knifed, replacement sucks
Old Mar 13, 2005 | 08:24 PM
tmorr01's Avatar
tmorr01
Default Top knifed, replacement sucks
About a month ago, some miscreant sliced through my top and headliner trying (I assume) to steal my car. I had the alarm set so I guess he/she ran off when after reaching inside through the top, unlocking the car and trying to open the door, the alarm must have gone off. Anyway, I just got the car back and although the top looks pretty much the same, the headliner is really cheap. The original was one piece while the new one is made of three panels sewn together. In addition, it no longer seals the interior from the top and there is much more wind noise now. I can put my hand between the headliner and the top. The rear of the headliner is attached to the bottom of the frame with some eleastic bands which I am sure wasn't how the original headliner was attached. Finally, there are some sheet metal screws holding the edges of the headliner to the frame at the top of the window. The dealer said this was now the replacement for the original and that GM must have swapped suppliers. Also, he said each headliner has to be individually fitted which is why the bands and screws. Has anyone else had to have their top replaced and does this sound "normal"? Oh yeah, it cost over $3700 to replace (insurance covered some).
Old Mar 13, 2005 | 08:47 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Man that sucks worse than haven the 1st top cut. I'd be back there. bands and screews. No way a proper replacement. Is this a GM dealer?
Man I feel your pain. Have you talked with your insurance co. about not being happy with repair? Best of luck
Old Mar 14, 2005 | 12:25 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Man that's not good. So now that the car is not being produced we are starting to get cheap replacement parts. Is this the case? But where else can you go? Man sometimes the General gets it all wrong. Why not have the original replacement and a cheaper one that customers can choose if they want. Or did the insurance company have something to do with what was choosen for the repair? Keep us posted. I hope you can get something done about this. Aren't they supposed to repair to original. Something fishy. My .02
Old Mar 14, 2005 | 07:00 AM
I agree, something just doesn't sound right. I'd be talking to the insurance company and tell them that you are definitely not pleased with the quality of the new top. Check around with a different dealer too to see if that is truly a replacement top from GM. Best of luck.
Old Mar 14, 2005 | 07:48 AM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I've seen new GM replacement tops here for about 20% of that price. $3000 + for the install? You're dealing with crooks.
Old Mar 14, 2005 | 09:01 AM
Fuelie driver's Avatar
Fuelie driver
A C5 replacement top with headliner runs between $700 to $800 plus labor!! I think you and the insurance co. got ripped!!!!!
Old Mar 14, 2005 | 09:05 AM
jrose7004's Avatar
jrose7004
Sorry to here about your top! Too back the car can't defend itself!
Old Mar 14, 2005 | 09:18 AM
C5 4 ME's Avatar
C5 4 ME
Old Mar 14, 2005 | 09:23 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Defiantly do some more investigating on this!
Old Mar 14, 2005 | 09:26 AM
ArmyVette's Avatar
ArmyVette
It's not clear to me. Did they replace just the fabric top or did they replace the entire convertible top assembly?
GM Parts Direct lists the entire assembly for about $3000 plus their horrendous "handling" charges so the total price plus shipping is about $3500+. The fabric piece is considerably less at around $1800 plus "handling."
Also, unless the insurance policy stipulate only OEM parts, they can replace it with an aftermarket item which normally has neither the looks nor fit of the OEM parts.
Old Mar 14, 2005 | 09:31 AM
ALX99's Avatar
ALX99
I changed my top about 2 years ago, I went from oak to black, all GM parts of course. What you describe sounds like you got ripped off. Try and compare it to someone else's vert if you can, this way you have all the correct info....
Old Mar 14, 2005 | 02:17 PM
tmorr01's Avatar
tmorr01
Thanks for the feedback. To answer some questions.The insurance co. didn't care where I got the top replaced nor did they specify where the parts came from. The parts were definitely GM equipment because I spoke to the parts manager at a Chev. dealer that ordered them. The install was done at a local repair shop and while that may say something about the quality of the install (not the issue), it doesn't address the quality of the parts which are gen-you-wine GM. One would only assume the frame was replaced as well for that amount of money. I assumed it was necessay although I don't think the frame was damaged. I'll touch base with other dealers though. Thanks.
Old Mar 14, 2005 | 02:21 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Since the insurnace company paid for the repairs, I would certainly touch base with the adjuster and voice your complaints to them. They can exert pressure to make sure the repairs are performed to your satisfaction (within reason).
And it is reasonable for the car to look at least as good as it did before the claim, especially for the amount of money charged to the insurance company.......jmho, of course!
Old Mar 14, 2005 | 02:24 PM
Tom/99's Avatar
Tom/99
You might want to check into that.
Old Mar 14, 2005 | 02:32 PM
2KVetteMan's Avatar
2KVetteMan
I take it to a GM dealer and have them look at the new top. Make sure the local repair shop didn't pocket the cash and Mickey Mouse you a crappy top.
Old Mar 14, 2005 | 03:15 PM
2toys's Avatar
2toys
This sucks big time and I feel your pain as a Vert owner.
As you've learned 99% of all new car dealers send their "trim" work out, called a "sublet". Find out who did your work, call other dealers and find out who they use and look in the Yellow pages for local trim shops. Take your Vert to several and ask them if they would inspect the replacement top and verify if it was done correctly. Use the carrot you're not happy and willing to pay to have it done to your satisfaction.
My .02
Old Mar 14, 2005 | 03:37 PM
tonyh2000's Avatar
tonyh2000
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03
May not of used the correct top. I also believe that at some point GM switched tops and they may have gotten one of the older models.
To Top knifed, replacement sucks
