pulling the engine - need help
Mar 14, 2005 | 06:47 PM
I am allmost ready to pull the engine. My question is, where do I bolt the chain to pull the engine using the engine hoist?
20 years ago, Iwe used the manifold bolts...don't think it will work with these
Mar 14, 2005 | 08:19 PM
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Hmmm, i'm looking to pull my motor this summer, However you'll probably get more responces in the tech forum.
Chris
Mar 14, 2005 | 09:07 PM
Heh.. Yep I did the same thing first time on C5..They don't come out from the top anymore. It has to come out from the bottom..
Mar 14, 2005 | 09:59 PM
Motors go in and out from the bottom. Gotta lower the cradel and all.
joe
Mar 14, 2005 | 10:21 PM
Quote:
Mar 14, 2005 | 10:28 PM
Quote:
I'm sorry guys, but i know they've come out the top before, you're right coming out the bottom is easiest when done on a lift, however i know of a few back yard mechanics who have pulled the motor out the top.
Chris
Mar 14, 2005 | 10:35 PM
St. Jude Donor '05-'06-'08
Manifold/headers
When you take the manifolds or headers out, use the same bolts and the chain goes where the those bolts bolt in.
Mine came out from the top with out removing hood, just got to be careful.
Mar 15, 2005 | 01:13 AM
You didn't take the hood off?
I assume you have the heads, manifold, waterpump (bare block) when you pulled it and bolted eveything back on after the install?
I can see liifting the block only using the manifold bolts since it should weigh much less minus everything else...
Mar 21, 2005 | 06:29 AM
Thanks, worked out fine. used 3" longg hardened bolts and was able to pull the motor from the top without any problems...
