Turn signal problem
Old Mar 14, 2005 | 07:33 PM
C5 fury's Avatar
C5 fury
Default Turn signal problem
My turn signals are experiencing an intermittant problem (2001 m6 coupe). The manual states that the turn signal relays are located in the hazard switch assembly located center console just below the upper dash pad.
When I firmly 'tap' the top of the dash above the hazard switch, the turn signals start to work.
Has anyone delt with this before? If so, was this a relay or possible connector problem? Also, any removal tips for removing the upper dash pad is appreciated.
Thanks for the help. Love this forum!
Old Mar 14, 2005 | 09:52 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I am surprized no one answered you yet, but yes the hazard switch is known to cause turn signal problems. If I remember correctly the switch itself isn't overly expensive, but the folks that have changed them have indicated that the replacement itself requires patience.
Old Mar 14, 2005 | 10:54 PM
RJH20dog's Avatar
RJH20dog
Old Mar 14, 2005 | 11:03 PM
flash134's Avatar
flash134
St. Jude Donor '05
I too had have the same problem, if you run a search on turn signals you may find the tread it gives pictures and step-by-step instuctions, good thread, wish i knew where i saw it? Anyone chime in if you know its whereabouts. Good Luck
Old Mar 14, 2005 | 11:11 PM
flash134's Avatar
flash134
St. Jude Donor '05
Heres the thread: http://forums.corvetteforum.com/showthread.php?t=860333 Hope this helps.
Old Mar 14, 2005 | 11:23 PM
BT-01-vette's Avatar
BT-01-vette
A tech told me that the because the hazzard switch is so close to the vent that they have had problems. The problems were linked to the heat from the center vent caused a defect switch
To Turn signal problem
