Well I got my new c6 chrome wheels from Bob's house of wheels and had Les Shwab install them and they Look Great! Thanks BOB!! But now one of my wheel sensors is not working. I reprogramed them all and they all beeped like they are good, but nothing on the right front, I got a XXX on the way to work this morning they say they take batterys could this be the problem? what type of batterys do they take?? or did les schwab damage one?? the car has 13k miles and is a 98 and every thing worked when I drove in any help would be great Thanks >>>>Greg
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
yes they do take batterys.. they take litium ion same as your watches might. I dont know the number ie ( 2032 or 1616 ) there a MANY.. but go to your local radioshack and pic up whatever number they are.. im sure someone on here knows the number!
Could be a damaged sensor or the battery could be going out. Unless you know how to get the sensor apart, you just have to replace the whole unit. There is a forum member here that does refurbish the sensors at a price cheaper than buying them new. A search may turn up his name.
The batteries in the sensors are not intended to be replaced. They are permanently sealed. There is one company that can rebuild them (I think they are called "Nericreations" for about $50). There is also a recent thread about one member's attends to replace batteries. He had about a 70% success rate after practice. You have to break the case to get to the "innerds".
More bad news, they are expensive to replace (I think somewhere around $90 per sensor for your model).
Unfortunately your best bet is to replace it if you can't get it to re-train.
PS - life expectency for the sensors is 5-7 years, so you are reaching the end.
