hoodliner paint
Mar 16, 2005 | 08:41 PM
Cruising
hoodliner paint
anyone know of the paint to freshin up the OEM black?? I assume it is a fabric paint of some sort??.. what is the contact info of the people that do them in airbrush??
thx!
Mar 16, 2005 | 09:16 PM
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Paula is the resident forum hoodliner person - if you look down towards the bottom of the list of vendors in the left nav frame you will find her web link.
Mar 16, 2005 | 09:29 PM
I used America's Finest by Rust-Oleum (available at Home Depot) ultra flat black and was satified with the results
Mar 17, 2005 | 12:10 AM
Cruising
Quote:
that was used to paint the material??? hmm I never thought that kind of paint would be ok I would think a fabric paint...
I cannot find Paula's contact info on that link??
Mar 17, 2005 | 12:12 AM
St. Jude Donor '03-'05-'06-'07
paula75032@sbcglobal.net
http://community.webshots.com/user/paulasartwork
Mar 17, 2005 | 08:47 AM
I used two cans of quality spray-paint on the liner. Helps a lot to make it a better surface to paint.
Good luck
Mar 17, 2005 | 09:39 AM
St. Jude Donor '03-'06-'07-'08-'09
Rustoleum Flat Black
directions are at
www.fixedroofcoupe.com
Mar 17, 2005 | 10:04 AM
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
With all of the above.
Mar 22, 2005 | 07:25 PM
Cruising
Quote:
Originally Posted by Vetteran
Tried Paula via email several times no reply???Does anyone know what type of paint I use for the colors in the airbrush???
Mar 22, 2005 | 07:38 PM
CI 6-7-8-9 Veteran
St. Jude Donor '07
Hi. I used hi-temp flat black BBQ grill paint in a spray can. Did 2 coats entire liner. Then finished off can on C5 emblem. I used fabric paint on mine rite out of the bottle. Some people have used glass paint. Both from fabric or hobie shop. I have not tryed air brush. Its a little like painting a sponge. Just take your time and you'll like it when your done. Took about a week to do mine- a little here and there allowing to dry in between.
Mar 22, 2005 | 08:55 PM
Cruising
one person told me they used testers paint??
Mar 22, 2005 | 09:06 PM
Cruise-In VII Veteran
Question
I have sprayed the flat black over the hood liner and coated the C-5 emblem numerous times. The red and white are soaking in verry badly. Is there anything else I can do besides give it more coats of red and white they now have around 6 coats and are still not bright.
Thanks,
Bob
Mar 22, 2005 | 09:15 PM
St. Jude Donor '03-'26
If I used Testor's paint pens how many of each color would I need to buy??
Mar 22, 2005 | 09:59 PM
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I just did
this .
Takes a looooooooonnnnnnng time.
Mar 23, 2005 | 07:07 AM
Cruising
doesn't look to bad...I airbrush... but it would be nice to KNOW what this Paula or others have used to get pro results???
Mar 23, 2005 | 12:23 PM
