Paging Sponge Vette....
Old Mar 17, 2005 | 03:03 PM
MSD44's Avatar
MSD44
Default Paging Sponge Vette....
Sponge Vette, you helped me out so much last time, I was wondering if you could pull another vin for me. It is a 99 vert, Black/Tan.
VIN# 1G1YY32GXX5121082
Thanks!!!
Old Mar 17, 2005 | 10:46 PM
MSD44's Avatar
MSD44
ttt
Old Mar 17, 2005 | 11:16 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Send him a PM, he might not see this thread.
Old Mar 20, 2010 | 08:12 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Thanks!!!
VEHICLE INFORMATION
Merchandising Model : 1YY67 Warranty Start Date : 03/12/1999
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : RUDOLPH CHEVROLET, LLC
5625 SOUTH DESERT BLVD
EL PASO , TX 79932-1158
(915) 544-4321
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
11/19/2001 308475 # C0182 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - RIGHT SIDE 26536 miles
11/19/2001 308475 # R4485 - TRANSMITTER BATTERY REPLACEMENT 26536 miles
11/19/2001 308475 # J3020 - RADIATOR FILLER CAP REPLACEMENT 26536 miles
11/19/2001 308475 # E7400 - SHAFT AND/OR SPHERE ASSEMBLY - REPLACE 26536 miles
10/25/2001 306914 # E7400 - SHAFT AND/OR SPHERE ASSEMBLY - REPLACE 25689 miles
10/25/2001 306914 # R4490 - REMOTE CONTROL DOOR LOCK TRANSMITTER REPLACEMENT 25689 miles
08/23/2001 302854 # V0743 - ECL RELAY HARNESS REPLACE 22308 miles
08/23/2001 302854 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 22308 miles
08/23/2001 302854 # D0362 - HEATER AND AIR CONDITIONING CONTROL REPLACEMENT 22308 miles
08/23/2001 302854 # E7100 - STEERING WHEEL HORN CONTACT REPLACEMENT 22308 miles
06/12/2000 272029 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 15960 miles
01/03/2000 261730 # C2860 - FRONT FLOOR CONSOLE REPLACEMENT 8366 miles
01/03/2000 261730 # C3231 - FRONT SIDE DOOR INSIDE HANDLE BEZEL REPLACEMENT - LEFT SID 8366 miles
01/03/2000 261730 # J6355 - POWERTRAIN CONTROL MODULE TRANSMISSION REPROGRAMMING WITH 8366 miles
10/27/1999 257766 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 7061 miles
10/27/1999 257766 # C0182 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - RIGHT SIDE 7061 miles
10/27/1999 257766 # J0690 - PULLEY, ACCESSORY DRIVE BELT IDLER - REPLACE 7061 miles
07/19/1999 250949 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 3996 miles
07/19/1999 250949 # T2020 - TOWING 3996 miles
02/22/1999 A21082 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1690 kg (3726 lb) Order Number : BGNS2R
Build Date : 02/22/1999
OPTION CODES
AAB AG2
AK5 AQ9
BGR B34
B84 CJ2
C05 DL5
DL8 FE1
FE9 G90
G92 IL3
JL9 K63
LS1 MX0
M30 NF2
NK4 N37
QD4 R8T
T82 T96
UN0 UV6
UZ6 U1S
U52 U75
VM3 V49
V73 XGG
YGH 1AY
1SA 41T
41U 67I
673
Click HERE
To see what the codes above are.
Old Mar 20, 2010 | 09:32 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Sponge Good to see you're still around.
Now look at the thread date. Only took you 5 years to reply.
Old Mar 21, 2010 | 08:53 AM
RSchleder's Avatar
RSchleder
At least he replied
Old Mar 21, 2010 | 09:02 AM
Oldvetter's Avatar
Oldvetter
5 YEARS TO REPLY !!!
BUT, it IS a thorough answer !
Good Job Sponge Vette !
To Paging Sponge Vette....
