oil pressure
Old Mar 17, 2005 | 08:28 PM
steves red vette's Avatar
steves red vette
Default oil pressure
my oil pressure just went up , driveing home from work. it went up to 68 any answers. steve.
Old Mar 17, 2005 | 09:06 PM
99 vett babycar's Avatar
99 vett babycar
ttt
Old Mar 17, 2005 | 09:08 PM
99 vett babycar
the C5 oil pressure sensor is notorious for its erratic nature and frequent failures. 60 psi is a little high but not way out. Just watch it for now and if it jumps up to 100+psi you need a new sending unit.You can do a search for "oil pressure" and you'll be over-loaded with past posts. Good luck.
Old Mar 17, 2005 | 09:17 PM
leaftye's Avatar
leaftye
Yep, sounds like your oil pressure sender is on it's way out. For a description of the problem and how to diagnose it, as well as a link for a how-to to fix it, check out the big link in my sig.
To oil pressure
