Caliper painting ?
Old Mar 17, 2005 | 08:34 PM
sureshot's Avatar
sureshot
Default Caliper painting ?
Id like to pull all my calipers off for painting, any tricks to not getting break fluid all over.
Old Mar 17, 2005 | 08:47 PM
dezcapt51's Avatar
dezcapt51
Can't offer much advice since I painted mine on the car
Old Mar 17, 2005 | 09:12 PM
BBates's Avatar
BBates
I also painted mine while they were on the car. If I was going to remove them I would go ahead and have them powder coated.
Old Mar 17, 2005 | 11:24 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I agree - why take them off? The 21mm bolt that holds them in place is torqued to 125 lb ft. Plus as I understand it, the plant puts some kind of Loc-Tite on them. I eventually got them off - but man what a pain!
My suggestion, paint them while on the car!
Old Mar 17, 2005 | 11:54 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
With all of the above. My avatar is my calipers done on the car.
Old Mar 17, 2005 | 11:59 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Not to mention the fact that you are going to have to bleed the brake system if you want to actually remove the calipers completely from the car. If you are just planning on painting the calipers I would advise you to paint them while they are still on the car. There is really no need to remove the brake lines from the calipers. However, if you are intent on doing so, here are some links.
http://www.hhdtexas.com/cf/tech/bleed.htm
This is a great tutorial for painting while on the car!
http://members.***.net/jhoover4/Hoover's_Web/corvette_projects.htm
Have fun, bro!!
Old Mar 18, 2005 | 12:06 AM
BJ98's Avatar
BJ98
Paint is the way to go. You may need to cover your entire car to make sure you don't get over spray. My son helped me with mine and only took one evening. Amazing what kids will do for a ride.........BJ98
Old Mar 18, 2005 | 12:28 AM
MikeJamesC5's Avatar
MikeJamesC5
I used the brush on paint. If I did it again I would cover my car and spray paint them. It would be a lot easier and probley look better. I kept getting hairs from the brush in the paint.
Old Mar 18, 2005 | 06:18 AM
sureshot's Avatar
sureshot
Ok Im convinced I’ll leave them on. The only reason I was looking to take them off is the paint suggests a minimum temp of 70 degrees before application. I’m in NY so we won’t be seeing those temps for a while; I was going to bring them inside to paint.
Old Mar 18, 2005 | 06:33 AM
lavla's Avatar
lavla
Default Leave them on the car!!
I did mine and left the wheels on the car! I just painted through the spokes of the wheels. Don't try it on the 97-99 wheels, though. The spokes are too thick.
Old Mar 18, 2005 | 07:12 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Yea, DON'T pull them off. Paint them in place.
Old Mar 18, 2005 | 07:16 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I painted mine with the calipers on and the tires off.
Old Mar 18, 2005 | 08:53 AM
ALLEGRO's Avatar
ALLEGRO
Mine turned out good without pulling them. Maybe you could reconsider?
Old Mar 18, 2005 | 08:59 AM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Leave then on......
Old Mar 18, 2005 | 09:19 AM
jrose7004's Avatar
jrose7004
I painted mine on the car! Just spend a lot of time masking with tape and newspaper and you should be fine!
Old Mar 18, 2005 | 08:48 PM
Z0SLIK's Avatar
Z0SLIK
Men they all look great!!
Old Mar 18, 2005 | 09:33 PM
rickko's Avatar
rickko
Paint them on the car.
Regarding heat to paint. If you can find those dual hi-intensity work lights that sit only a few inches off the floor at Harbor Freight, they'll pump out enough heat in the vicinity of your work to do it in the cold. (You might freeze but your calipers will be warm, hehee).
Regarding brush hairs: Apparently you were using a cheap brush. Home Depot sells an 'Artist Kit' brush set for about $5. It has about 5 brushes in it of fairly good quality. I'd recommend it.
I painted my calipers for less than ten bucks for 1/2 pint of paint and supplies vs. buying Z06 calipers for $399 & up to $200 for labor. Woohoo!
..rickko..
To Caliper painting ?
Old Mar 18, 2005 | 10:43 PM
DocToss's Avatar
DocToss
What kind of paint did you all use? I have a silver vert, has anyone painted them silver?
Old Mar 19, 2005 | 12:06 AM
Stickman81's Avatar
Stickman81
I removed the calipers and brackets in order to get my rotors off for painting too. I did not disconnect the brake line. I covered the car with paper.
I used "VHT" brand spray paint which I got from Autozone.
Good luck and have fun.
Before
After
Old Mar 19, 2005 | 02:03 AM
MackIII's Avatar
MackIII
Before
After
Is that a new rotor you put on or how did you clean them up that good?
