I would say that it's for a convertable.
FRC and coupe have fixed antennas.
by the way, I bought a $3:00 switch from radio shack and wired it into the antenna power wires in the harness located in the passenger side footwell.
works GREAT!
The antenna goes up when it gets power from the factory deck , putting in one of the described switches removes power so the antenna goes down and the radio can remain on . Personally I would install a better (aftermarket) unit which only raises the antenna when you choose the AM/FM feature . Plus side is better sound also .
The Tech Tip is good information. I saved a little time by using a non lighted switch which requires one less wire connection. I mounted my switch in the arm rest next to the power plug and it looks factory and is out of the way. I hated always taking off the antenna to put the cover on so this is a welcome mod. Good Luck
I would love to get my hands on a schematic for the Delco radio and add a little circuit to raise the antenna only when the AM/FM radio is selected. But so far I have not found an aftermarket product that does this nor have I had any success in getting a schematic. Delco wouldn't respond and a Corvette Radio shop (response below) told me they are not available. So if any of you have any leads on this let me know. I'll share my findings. Thanks.
John
Schematics to these radios are not available.
Like wise the output wiring is all bose equipped and is therefore not available.
-- Thank You for Choosing Doctor Don's
Doctor Don's
225 FM 247
Huntsville, TX 77320
ph 936-435-1811
fax 936-435-1602
[QUOTE=Cscokd]I would love to get my hands on a schematic for the Delco radio and add a little circuit to raise the antenna only when the AM/FM radio is selected. But so far I have not found an aftermarket product that does this nor have I had any success in getting a schematic. Delco wouldn't respond and a Corvette Radio shop (response below) told me they are not available. So if any of you have any leads on this let me know. I'll share my findings. Thanks.
John
[I]Schematics to these radios are not available.
Humm, I'm sure that I saw the output wiring schematic in my 04 Service manual. The only wire that seemed useful was the A8 dark green one that is the radio power signal wire. But, it needs to be switched if you want to control the antenna more than radio on/off.
