[Z06] Oil Life
I believe the manual recommends 10,000 miles or at least once a year. I use a combination of oil life remaining and time.
Castor oils are vegtabled based. They are a great lubricant, but don't last very long (they have a very low flash point). This is where the 3,000 mile rule came from - the 1908 period. Somehow it has stuck to this day. Of course it makes no sense today. It is just an old adage. Of course it doesn't hurt to change it that often, just like it wouldn't hurt to wipe your dipstick with a $100 bill after you check the oil and throw it away. Both practices are a waste of money.
A Mobil engineer told me 15,000 miles was an appropriate oil chang interval. I change mine when the DIC gets down to 5%. Following an old, bad habit, I changed mine at 1,000 miles, again at 10,000 miles and at about 18,000 miles (when the DIC got to 5%). I have had to add a quart of oil once between these oil changes.
As a shareholder of Exxon Mobil, I thank you guys who change your oil every 3,000 miles. If that makes you feel good, why not change it every 500 miles. Think how much better you would feel.
I do miss the smell of that castor based two stroke racing gas in my old BSA flat tracker.
How much cleaning could an oil filter that is 10,000 miles old do? Seems like if you are going to change your oil at such large intervals the filter should be changed more often. No?
If you use a pure synthetic, you are not gaining anything at all by changing your oil more often than 7000, 8000, or even 10k miles.
You won't HURT anything by changing every 3k miles, but all you're doing is throwing money away *edit* Actually, it COULD be hurting things by changing so often, see my post below*
Go by your DIC. Your car knows when it needs oil.
http://neptune.spacebears.com/cars/stories/mobil1.html
One key quote:
Engine wear actually decreases as oil ages. This has also been substantiated in testing conducted by Ford Motor Co. and ConocoPhillips, and reported in SAE Technical Paper 2003-01-3119. What this means is that compulsive oil changers are actually causing more engine wear than the people who let their engine's oil get some age on it.
And if you wanna get really crazy, read about this Mack truck engine tear-down after running 409,000 miles without an oil change, using Amsoil synthetic.
http://www.performancemotoroil.com/409000
LOL
I used to be a 3,000 mile/3 month oil guy as well, but after becoming an AMSOIL dealer last year, reading hundreds of used oil analysis reports on engines that went well past 3,000 miles, and studying what the norm is in Europe, running engines not much different than ours, I am now a believer in longer drain intervals.
In my wife's Chevy Trailblazer, I run AMSOIL XL-7500 Synthetic 5w30 and follow the oil life indicator. Last two changes were each six months, 9k miles on one, 6.5k miles on the other. For my F350, I use Series 3000 Synthetic 5w30 Heavy Duty Diesel Oil and am changing the oil at 15k miles or six months, with a filter change at half either.
For my vette, as it sees only track use, I use much more frequent oil changes.
Here are a couple interesting articles on oil change intervals written by the editor of Lubes and Greases. Note, these were writter prior to Mobil's recent release of the new Mobil Extended Performance 15k mile oil, which compares to the 25k mile AMSOIL SAE synthetics.
Motor Drain Intervals: How Long Must We Wait?
Motor Oil Drain Intervals: An Ethical Burden?
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
What is wrong?
