How do I remove clear coat scratches?
Old Mar 19, 2005 | 11:29 AM
04SeaFive's Avatar
04SeaFive
C7 of Year Finalist (performance mods) 2019
Default How do I remove clear coat scratches?
I have a couple of scratches in the clear coat of my LeMans Blue vert. Don't know how they got there, but they bother me. What's the best way to remove them? If w/ compound, please give me a name or grit?
thanks,
O4 SeaFive
Old Mar 19, 2005 | 11:36 AM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
might not even need compound although that is a possible choice and would work the best obviously. But they make stuff that you wipe on and off its called quick detail.. I believe that should work fine.. it has helped get surface scratches out that are caused by pretty much anything. You can find it at pep boys, or even possibly CVS
Old Mar 19, 2005 | 12:10 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
McGuires scratch remover works for me.
Old Mar 19, 2005 | 12:29 PM
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
How deep are the scratches 04SeaFive? If you run your fingernails across the scratch, will your nails catch in the scratch? Do you own any kind of Buffing Machine or Polisher? By the way, I own a national aircraft detailing company and I'm sure I can help.
Richard
http://www.wingwaxers.com
Old Mar 19, 2005 | 01:14 PM
DaBoz's Avatar
DaBoz
Start with this: http://www.meguiars.com/store_meguia...-103&store=meg
This will be helpful: http://autopia-carcare.com/freeguide.html
Old Mar 19, 2005 | 01:22 PM
love my car's Avatar
love my car
3 m has a sratch remover that wrked for me. Make sure the cars clean ,no dust on it works well got it at auto zone.
Old Mar 19, 2005 | 01:24 PM
love my car
Richard
Dont mess with a buffing machine unless you know what your doing,can make matters worse with swirl marks!!!
Old Mar 19, 2005 | 04:12 PM
04SeaFive's Avatar
04SeaFive
Thanks, I look for it.
Old Mar 19, 2005 | 04:18 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Might check this out too ...
http://www.thedetailingbible.com/
Old Mar 19, 2005 | 04:32 PM
04SeaFive's Avatar
04SeaFive
Originally Posted by DaBoz
thanks.
Old Mar 19, 2005 | 05:32 PM
scott_fx's Avatar
scott_fx
i went to the meguires detail clinic and they showed us the over the counter scratch-x. he worked the product into the scratch with 3 applications (must be done by hand with some pressure) and the scratch was gone. try that first, it's probably the safest thing to try first.
Old Mar 19, 2005 | 06:48 PM
C5Jim's Avatar
C5Jim
3M makes the best stuff. Excellent results.
Old Mar 19, 2005 | 08:56 PM
04SeaFive's Avatar
04SeaFive
thanks,
O4 SeaFive
thanks to everyone for your replys and suggestions. I bought some Maguires Scratch X today and it did the trick.
04 SeaFive
Old Mar 19, 2005 | 09:17 PM
DaBoz's Avatar
DaBoz
04 SeaFive
This site is great... answers to your questions and too many ways to spend your money.
Old Mar 19, 2005 | 09:45 PM
iceburgh's Avatar
iceburgh
St. Jude Donor '03-'04-'05-'06-'07-'10
Start with Meguairs ScratchX if that dies not work an dthey are deep go to #80 glaze hen if that does not work use Meguairs fine cut cleaner.
I would try scratchX first and if yyu have an orbital it will take care of it.
You might want to consider an orbital buffer.
www.meguiars.com can give you more detail and alos be able to buy what you need
Old Mar 19, 2005 | 10:46 PM
I use a product called Adam's Polishes Scratch Out - works well. Can be bought through the manufacturer or West Coast Corvettes. 3M makes a good scratch remover too.
Old Mar 19, 2005 | 11:46 PM
Korbo's Avatar
Korbo
Today was only the second day in a month of ownership that I could wash the car. Sadly I discovered some clearcoat scratches also along with the swirls the dealer gifted me with. Scratch X did the trick for me too and made me feel a lot better. After claying and getting my first coat of Z5 on the swirls are a little less annoying also. Life is good at least until tomorrow when the rain and snow are predicted to return.
Old Mar 20, 2005 | 12:03 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Zaino
www.zainobros.com
To How do I remove clear coat scratches?
