Need the GM Part # for the latchs that secure the rear well covers, the part looks like a pin with a rubber gromet, when pushed to the down position they lock the covers in place. I need 2 for the cover that goes over the CD changer. Thanks for any help
It may be a non-serviceable part......meaning it is sold as part of the cover. There is a retainer listed and this is not serviceable. If it is infact here are the cover part numbers. There is a latch part number listed as 10290666 and this may be what you need.
If it turns out that you need the whole cover, here are the part numbers.
The center cover in black is 10413526.
The RH cover in black is 10434933.
The LH cover in black is 10413530.
I'm guessing that you meant for the center compartment. Let me know if you needed one of the side compartments instead.
Paul
yes the center compartment; I don't want to by the whole cover so i will see if I can get the latch only....Thanks, Dave
