Traction Control/Active Handling.....
I only drive in comp mode anymore, I don't like the traction control but the a/h is AWESOME!!!!!
Now that its established I have AH and TC, I can't seem to go into the Competetion mode. I've tried doing the 5 second, 10 second press on the button thing. But no change... I don't get that "Competion Mode" message in the DIC. What am I doing wrong ?????????????? Plz help!
Thanks in advance to everyone and this forum...
The 2nd Generation AH was introduced in model year 2001. With 2nd gen AH, the Competitve Driving Mode can be enabled while the car is moving.
For either generation of AH, when you switch the ignition to off, the system will revert back to the default setting of TC/AH both on.
Hope this helps and good luck.
When I expect the car to do something(get sideways around a hard corner, etc.) and AH/TC kicks in and stops it from doing what I expected it to do, it can be more frightening than the actual controlled loss of traction. Sometimes you need that controlled loss of traction to balance the car during aggressive driving. Sometimes drifting through a corner is the fastest way through that corner, AH/TC doesn't like that.
I think better drivers may find it a hinderance to performance driving. On the other hand, less experienced drivers and drivers of all skill levels can benefit from the systems during poor weather/driving conditions.
I guess it has it strengths and weaknesses. All I can say is that I am glad it is switchable.
AZC5
P.S. My first vette did not have AH or TC, I learned how to drive hard without them. Maybe thats why I dont care for them too much.
Hit 2nd and all hell breaks loose
backend comes around, turn into it and it goes the other way. I go a couple more seconds of this back and forth and decide to shut her down. Save the car and what little self respect I have left. I like Active Handleling!
So here's the questions once again;
1. How to get comp driving mode with A/H operational.
2. How to get comp driving mode with A/H switched off too.(Xtra fun)
I have the handbook but it still doesn't make it clear...well not to me anyway.
push the button one time = AH & TC off
Push the button and hold it for five seconds and the competative mode flashes in the DIC = AH on TC off
mine too
