Help: Removing factory side molding???
Old Mar 20, 2005 | 09:32 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Default Help: Removing factory side molding???
I want to remove the factory side molding from the doors/front fenders on my 01 c5. Are they attached by 3m tape? Has anyone done this? Any tricks or tips?
Old Mar 20, 2005 | 09:43 PM
Antvette's Avatar
Antvette
Veteran: Marine Corps
I took mine off not too long ago. It's held on by rivets and lots of other good and paint harming stuf...J/K. Get some STRONG fishing line, and some GooBGone and saw through the 3mm tape that holds it on. Be careful not to rip it off as you might take some paint with it. Good luck.
Old Mar 20, 2005 | 09:48 PM
MyOwn69's Avatar
MyOwn69
You can do a search for this - it's been posted many times.
That last response was correct - I used a 30 lb. fishing line and just "sawed" my way front to back. Don't be in a hurry - I think the friction helps break down the glue that holds them on.
Others have used a blow dryer - I didn't find it worth the bother. Goo-Gone, or some bug remover, or WD-40 should clean up any left-overs.
Just take your time - there's no hurry!
Good luck
Old Mar 20, 2005 | 09:49 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Rule #1: Take your time.
Rule #2: Use a heat gun or hair dryer to help loosen up the adhesive.
Rule #3: Use the heaviest fishline to cut through the tape.
Rule #4: Do NOT start to pull them once you get the first part away from the body.
Rule #5: Take your time.
Trust me on all the above.
Did I mention to take your time??
You'll love the look when they are off and it's all cleaned up.
Old Mar 20, 2005 | 10:27 PM
MDriveMode's Avatar
MDriveMode
Are you saying that there will be holes that I will have to fill on the body?
Old Mar 20, 2005 | 11:29 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
No - they were kidding you about that. The BSM's are held on only by some real strong double sided tape.
Old Mar 20, 2005 | 11:40 PM
wildman378's Avatar
wildman378
leave the bsm's on they look better with um IMO
Old Mar 21, 2005 | 12:33 AM
GrayC5's Avatar
GrayC5
Welcome to the Forum!
As mentioned above, you should be able to find a number of threads on this topic using the Forum Search feature. Good luck.
Old Mar 21, 2005 | 12:41 AM
BlownV6's Avatar
BlownV6
Let the car sit in direct sunlight for a good hour then go to work with the fishing line.
Old Mar 21, 2005 | 01:14 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
Your going to love the look. Welcome to the forum.
Old Mar 21, 2005 | 06:57 AM
The molding is held on by two sided tape. You can use a hairdryer to heat the molding (softens the tape) and then take a piece of strong fishing line and "saw" the molding off. You will have some tape residue left to clean off the side of the car. Just be careful - I saw a post not too long ago where the owner was removing the molding and in at least one spot the paint came up also when he pulled on the molding.
Old Mar 21, 2005 | 09:48 AM
Kschwamy's Avatar
Kschwamy
Just finished my wifes car and the above directions are perfect. I used 30# fishing line but could have gone to 40#. Used a decal application tool to take off the heavy remaining residue then used the Goo be Gone then buffed with Griot's Machine Polish 1, 2, 3 and you can't tell they were wver there after 8 years of being on the car. Good luck.
To Help: Removing factory side molding???
