Turning Off Memory Seats
Old Mar 21, 2005 | 06:48 PM
racecar2001's Avatar
racecar2001
Default Turning Off Memory Seats
Is there anyway to disable the memory seat without disabling the power funtion of these seats. I seam to have a problem reprogramming the seats for the position I want. Thanks for you help
Old Mar 21, 2005 | 06:52 PM
mcronec5's Avatar
mcronec5
Cruise-In VII Veteran
I think its under options on the DIC. Easy entry, exit or something like that.
Old Mar 21, 2005 | 06:56 PM
racecar2001
I tried that but I can only turn easy entry on or off not memory on or off. I purchased the car used and every time I lock and unlock it it returns to the original memory positon for that FOB
Old Mar 21, 2005 | 07:18 PM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
Get the seat in the position you want, look on the back of the key fob for a "1" or "2", and press and hold down either 1 or 2 on the top of the pad on the driver's door until the yellow light blinks. This will enter a new memory setting (yours) for the seat...at least I think it works like that. The owner's manual should give you the correct procedure.
Old Mar 21, 2005 | 07:23 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
You can also program a third position by holding down both 1 & 2 at the same time. Once you see the led blink at you you can let go of the buttons. Let us know how you do.
Old Mar 21, 2005 | 08:17 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Old Mar 21, 2005 | 09:00 PM
StevieB's Avatar
StevieB
Sometimes ours malfunctions and will not go the programed position. When that happens sometimes all of the seat controls stop functioning. It pis*es me off, because our Chrysler works first time, every time, never had a problem. Oh well, what do you expect for a 50K car.
Old Mar 21, 2005 | 09:40 PM
ALLEGRO's Avatar
ALLEGRO
'Tis the Answer !
Old Mar 21, 2005 | 09:47 PM
SmashF15C's Avatar
SmashF15C
Yeah it's not his technique, fellas, some of the memory gets 'elderly' to put it nicely. No matter the order of door/key/seat button, etc.
Just need a new seat module probably or track. I was going to get to it this winter but my 6K/mo house habit (winter=outdoor mod time here in FL) is killing me. Almost done. At least it's worth 2x what I paid 2 years ago. But I digress.
Maybe I'll post the 'memory loss' fix this winter.
Later,
Smash
To Turning Off Memory Seats
