Tire installation question
Old Mar 22, 2005 | 03:28 PM
BigTMan's Avatar
BigTMan
Default Tire installation question
Thanks for all the feedback on tire selection.
I have ordered Pilot Sport AW ZP tires. I got them from a local tire dealer. Will be in in a few days, they said they know all about handling the Corvette. I haven't any expereince yet with the Vette as far as jacking or tire changes etc. I do know they will have to have pucks to raise the car.
Anything else I should watch for?
Old Mar 22, 2005 | 03:34 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Yes, they should remove your tire pressure sensors before they try to remove the old tires from your wheels. They do this by removing the core from the valve stem to let the air out, then unscrewing the retaining nut from the base of the valve stem and dropping the whole sensor into the tire. Then they can break the bead and reach in to take out the sensor. The installation process is explained here
PS - putting new tires on is a great time to put in sensors with fresh batteries....
Old Mar 22, 2005 | 04:22 PM
JackTsDBG's Avatar
JackTsDBG
Everything anybody needs to know about handling EMTs:
http://www.hunter.com/pub/undercar/PPT/index.htm
Old Mar 22, 2005 | 05:15 PM
Be sure they know about the tire pressure sensors, and that they have the equipment that will not put scratches in either the outer or inner surfaces of the wheels.
Old Mar 22, 2005 | 05:21 PM
HummelS's Avatar
HummelS
A lot depends on the type of lift they are using. Just about anything that will prevent direct metal contact of the lift arms with your rocker panels (even a piece of cardboard) will work, as long as they use the correct lift points on the frame.
Old Mar 22, 2005 | 05:23 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I'd certainly ask to have the balancing done on a Hunter Roadforce machine, if you have a choice......
Old Mar 23, 2005 | 02:52 PM
BigTMan's Avatar
BigTMan
Thanks for all the feedback. I feel more prepared, didn't know if anything had to done with the stem sensor.
Old Mar 23, 2005 | 03:15 PM
gregk1's Avatar
gregk1
I just had new wheels put on, and the tire shop messed up three of my sensors, because of the way they did all the work. But they took care of me and I got three new sensors on them and I paid for one, so now I have all four new, Thank you Less Schwab, they were verry good about it and I think they will have a little classroom workshop on what they need to do about runflats and sensors
Old Mar 24, 2005 | 08:21 AM
BigTMan's Avatar
BigTMan
I printed off the insructions sheets from the link on one of the above replies, to take into the tire shop. Will probably Pi$$ them off, but hey! its my car!
To Tire installation question
