Need Help Asap
Old Mar 22, 2005 | 09:20 PM
DreamVette97's Avatar
DreamVette97
Default Need Help Asap
Trying to put on new shift **** on my 97 6 speed and can't the the factory T pin to come out. I have pryed it with a flathead for 15 min and it aint budgin! ANY suggestions?
Old Mar 22, 2005 | 09:22 PM
TANGLVR's Avatar
TANGLVR
Did you pop the gear number plate at the top and remove the screw?
MM
Old Mar 22, 2005 | 09:24 PM
DreamVette97
I just took the number plate out and now i am trying to pry the T pin underneathe it. Did I forget to do something?
Old Mar 22, 2005 | 09:29 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
http://www.vetteessentials.com/instr...t_install.html
Thank Ken King at Vette Essentials for his usual excellent instructions.....
Old Mar 22, 2005 | 09:30 PM
full moon's Avatar
full moon
St. Jude Donor '11-'12-'13-'14
check this out.....
RockinC5's Avatar
RockinC5
Here's a tech tip that might help ya out
Old Mar 22, 2005 | 09:31 PM
SlideRulz's Avatar
SlideRulz
https://www.corvetteforum.com/techti....php?TopicID=1
It's about 14 lines up from the bottom of the page.
Old Mar 22, 2005 | 09:34 PM
DreamVette97
THANKS black sedan and ken!!!! That thing is being a B@#$H!
Old Mar 22, 2005 | 09:35 PM
mcronec5's Avatar
mcronec5
Cruise-In VII Veteran
MM
There is no screw. Is there????
DreamVette97
WOW!! thanks again to ALL that posted. This forum is GREAT!
Old Mar 22, 2005 | 09:41 PM
KBlanke's Avatar
KBlanke
get two medium flathead screwdrivers and put one under each side, gently pry on both sides at the same time. You also need to find something to put under the screwdriver blades to keep from scarring the shift ****
Old Mar 22, 2005 | 09:48 PM
speedfreek155's Avatar
speedfreek155
Thanx Guys , a new shifter is my next mod . Gonna save me some time.
THIS SITE IS AWSOME !
Old Mar 22, 2005 | 09:50 PM
DreamVette97
KBlank, thats what I ended up doing. It worked great! The new MGW Bullet shifter looks great too. If you guys are thinking of getting one, or anything else from the MGW site, GO FOR IT! I ordered mine on Monday a.m and got it today at 5. FAST shipping!
To Need Help Asap
