Lexan Top Owners....
Mar 24, 2005 | 08:20 AM
Pulled the glass top out of the garage and to my horror (discredit) saw tiny specks of red paint (overspray) on it. Then I remember.. dumb azz me! It was in the garage uncovered when I painted my calipers in early winter.
I know you have to be careful about what you use to clean the top to prevent scratching, but does anyone know if using a claybar on the top would be dangerous. TIA
Mar 24, 2005 | 08:46 AM
Try using Meguires cleaner wax, It may take some work, but it should remove the overspray without any adverse affects.
Mar 24, 2005 | 08:48 AM
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
I would also try a clay bar, use plenty of water
Mar 24, 2005 | 09:12 AM
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Mar 24, 2005 | 09:14 AM
Quote:
Originally Posted by ptdrummer54
claybar and lubricant...
The lubricant can be straight water, detailing spray, or a water/car wash detergent (Zaino Z-7
) solution. Just make sure the claybar and car top are both wet.
Mar 24, 2005 | 09:46 AM
overspray
& soapy water...
Mar 24, 2005 | 10:51 AM
St. Jude Donor '05 thru '19
I would only use stuff made for Lexan, Novus makes a lot of cleaning products specifically for Lexan.
Mar 24, 2005 | 11:16 AM
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Hey man,
Sorry about the messed up top. Hope you get it all off OK.
Now ya gotta show us some pics of your painted calipers.
Mar 24, 2005 | 12:54 PM
Claybar should work fine as long as you use plenty of detailing spray. Good luck getting the overspray off.
Mar 24, 2005 | 07:23 PM
Quote:
This makes good sense
Mar 25, 2005 | 12:08 AM
Doesn't the Lexan have a tint film over it? That might need something else.
Mar 25, 2005 | 12:19 AM
If you check the owners mannual, it points out that only certain types of glass cleaner should be used. BE CAREFUL before you start using anything stronger. If you do use sometype of other cleaner, I would test it in a spot that won't show.
