Codes
This is what I got from the dealer:
A report on cust states oil pressure fluxuates while running. Possible oil pressure sender???now is stuck 130psi whil driving
4 engine mechanical & related repairs
26 CSCL
33 CSCL
Checked the oil pressure gage inaccurate. Scanned the instument panel cluster. Performed a sweep test. Gage reacts OK. Checked the codes.
Lo SS of cam codes. Not related. Checked the circuit. Found problem with sender. Recommend replacing. Another technician replaced the oil pressure sender and rechecked the oil pressure gage. OK. 40 PSI.
