I saw one recommended by the forum. It is corvettepartitions.com
Which company has the best one to use ? I have a98 Vert. and want to reduce the noise . Thank you, habib
I just got the corvettepartitions partition for my vert. First rate quality and Brian is a great person. Really stands behind his product. Even called me after I got it to make sure I was satisfied.
It comes with velcro tabs but the fit is so good that I don't need them. I did the Frost King mod just before I installed the partiition. Now my exhaust sound stays outside the car. I run Corsa Indy's and if I want to hear them I put the window down, A great addition to the vert. You'll love it.
Every partition vendor on this forum seems to get great feedback so I think you will be fine with whatever vendor you end up going with.
I ended up going with www.pfyc.com and only spent $150 for my vert partition. They have a version made from MDF board and it provides a lot of sound deadening. it also looks great and fits perfect.
But, if you use your trunk storage compartment a lot, you may want to go with the versions from corvettepartitions.com or exoticvette.com. They have ABS plastic versions with a bend in them to access that compartment.
Either way you go, you will like it. The partition is a great mod.
I did some research and decided on Exotic Vette's. Dan is a 1st rate guy and customer service is great! Here's a couple photos of the install in a mag. red/lt. oak interior. Color match is perfect and it requires NO adjustment to put the top down! Very important feature!!
From: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
St. Jude Donor '05-'06-'07
