Proper Pressure for EMTs
Old Mar 27, 2005 | 08:53 PM
1stTimeVette's Avatar
1stTimeVette
Default Proper Pressure for EMTs
Can anyone help me with the proper pressure that I should be keeping in my GY EMTs? I drive my 2004 CE Vert probably 2 times a month, and the rest of the time it sits covered in my Southern California garage. It takes awhile for the tires to warm up, and they start out at about 25 psi and then warmed up go up to about 29-30psi. I have heard that 30 psi is perfect, but if I fill them while they are cold, they will be well above 30 psi when warm. Help me out here. Thanks and Happy Spring to all in snow country.
Old Mar 27, 2005 | 08:55 PM
vetterlatethannever's Avatar
vetterlatethannever
Mine are about 28 when cold and then when they heat up they sit nicely at 30 PSI.
Old Mar 27, 2005 | 09:04 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
30 psi when cold
Old Mar 27, 2005 | 09:08 PM
ALLEGRO's Avatar
ALLEGRO
Originally Posted by Zilla
30 psi when cold
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Corvettes perform better when you give them regular exercise.
Old Mar 27, 2005 | 09:16 PM
Blue Lion's Avatar
Blue Lion
30 cold is the answer you'll get all day long here...
Old Mar 27, 2005 | 09:23 PM
Shall's Avatar
Shall
St. Jude Donor '05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-‘16-‘17
Should also be on the driver door, with info for both hot and cold.
Old Mar 27, 2005 | 10:48 PM
gordonb50's Avatar
gordonb50
30 psi cold ....
Old Mar 27, 2005 | 11:00 PM
T's's Avatar
T's
St. Jude Donor '06-'07-'08
If I go below 28 by DIC goes crazy !
30 cold
Old Mar 27, 2005 | 11:17 PM
GrayC5's Avatar
GrayC5
30 psi when cold
Yep, the car's tire loading label found on the driver's door is a good place to start.
C5 Convertible Tire Loading Label:
Old Mar 28, 2005 | 12:17 AM
C5 4 ME's Avatar
C5 4 ME
30 psi when cold
I'm in So. Cal too.
Old Mar 28, 2005 | 06:49 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
30 psi when cold
Old Mar 28, 2005 | 06:52 AM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
Tire pressure should always be checked when cold. I run 30-32.
Old Mar 28, 2005 | 07:00 AM
1stTimeVette
Default 30 psi cold......................I got it!!!
Thanks everyone. You guys are great. Best forum on the web. By the way, I wish I could take her out more often than 2 times a month, but being a working man, I have to pay for her as well as the rent and the kids..............................you know what I mean.
Old Mar 28, 2005 | 07:03 AM
30 psi cold is the correct pressure. They will heat up to about 33-34 psi when hot, but that is normal.
Old Mar 28, 2005 | 10:51 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
30 psi when cold
To Proper Pressure for EMTs
