Bad Clutch?
Old Mar 28, 2005 | 11:35 AM
2K1 6T8's Avatar
2K1 6T8
Default Bad Clutch?
How can I tell if my clutch is going bad and needs to be replaced?
It might be my imagination, but when shifting it seems like I am not getting "full power" to the wheels for a second after I shift......
Old Mar 28, 2005 | 11:41 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
If you tach goes and not your speedo then its probally slipping and you should smell it burning ..probally not much help but I am not expert ,good luck.
Old Mar 28, 2005 | 11:43 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Shift from 1st to 2nd, floor it when letting out the clutch...if your tach zooms skyward but your MPH does not...it's slipping....
Peace
Willfulone
__________________
..................Click for
Old Mar 28, 2005 | 11:44 AM
ericdwong's Avatar
ericdwong
Drive 50 mph in 5th gear, and floor it. If the clutch slips then its time for replacing.
Old Mar 28, 2005 | 01:07 PM
XTREEME's Avatar
XTREEME
Were you doing some hard driving on it just prior to it happening? Then, after it cooled off, you tried to get it to slip again, but it didn't?
The stock clutches on the C5 are pretty tough, but the first signs of replacment are in the situation described above.
You'll probably be ok in normal driving for a while. But the next time you do some hard driving, and you really want that pull in 3rd gear, it probably won't be there.
To Bad Clutch?
