Help need this
Old Mar 29, 2005 | 07:46 AM
WHEW64's Avatar
WHEW64
Default Help need this
I purchased a used Blackwing air filter on the internet and it must have been on a 2001 or newer model because it did not have the gasket at the top of the filter used on 97-99 models because on later models it is removed and replaced with a tube. Someone out there must have put a Blackwing on a 2001 or newer and still has the gasket that was supplied for the 97-99 model. Any suggestions.
Old Mar 29, 2005 | 09:07 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I guess you could try posting in C5 Parts - or you could talk with a dealer to see if they could order one for you....
Old Mar 29, 2005 | 11:40 AM
WHEW64's Avatar
WHEW64
Tried both of those with no luck.
Old Mar 29, 2005 | 12:02 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Try Donaldson then - here's their info:
[I]There is no better team to provide you with assistance than ours. At Donaldson, we have the technical experience to assist you in finding the correct product for your application. We’re easy to reach and happy to help.
If you need additional assistance, please contact customer service at 800-374-1374 or 952-887-3699.
Old Mar 29, 2005 | 12:50 PM
I agree, give Donaldson a call. They should be able to give you some help.
Old Mar 29, 2005 | 04:54 PM
WHEW64's Avatar
WHEW64
Thanks, I will call Donaldson
To Help need this
